Conext SW 4048 Fault F17
jorge22
Registered Users Posts: 1 ✭
hi i did install my system 2 weeks ago, today everything was working perfect after i got a beep sound on my inverter and the fault code F17. The inverter stop working. I pressed the reset button but the warning red light still on. How i can fix that error?x please helpppppp.
Fault 17, AC backfeed from welded relay, service required. Sounds iike it's a warranty issue if only 2 weeks old.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
