problems with renogy rover 40
rock1212
Registered Users Posts: 1 ✭
the unit is showing no amps to the battery, using s multimeter I have power to the unit and power to the batteries. the % of batterie is 61%. I also have a victron battery monitor it shows 91%. the victron is monitoring the house batteries and starting batteries , the renogy is only connected to the house. there is light power consumption (bilge ) not sure what to do
How are you measuring this?rock1212 said:the % of batterie is 61%.
Does the Charge controller show the voltage from the solar array? If so Can you start a load on the battery bank and see if the charge controller doesn't think your batteries are fully charged and starts to allow charging to compensate for the load?
