charge controller and mate3
reeree
Registered Users Posts: 1 ✭
The meter bar for the charge controller doesn't appear on the home screen although it is hooked up.
I have rebooted the charge controller and the mate3, but can't get it to come on.
Any help with this?
Any help with this?
Check the port it connected to per install info . Maybe check you have set the pv size on the mate .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
