24v,
seedguy10
Registered Users, Users Awaiting Email Confirmation Posts: 3 ✭
I am trying come with a solar system to power a sprinkler clock. The requirement is 24v, 1.8 amp .
I haven't been able to find a prepacked one so I need help. Any ideas?
Welcome to the forum Seedguy,
Generally, the place to start is to understand how much energy (amps, volts, just running clock, cycling/holding water valves, etc.).
For example, if you needed 1.8 amps @ 24 volts for 24 hours per day:- 1.8 amps * 24 volts * 24 hours per day = 1,037 Watt*Hours per day
Then the other is how much current the solenoid takes... There are those, full size, that pull current whenever they are "on"... And there are others that are a small solenoid that channels water pressure to the main valve and pull much less current, or possibly only pull current when cycling off to on and on to off.
Here is an example of a single solar valve that uses almost no energy (solar panel only several inches in size):
https://www.dripworks.com/dig-leit-solar-timer-with-1-valve
To full blown commercial timers (not cheap):
https://www.ewingirrigation.com/products/controllers/solar/leit-x-20-station-solar-irrigation-controller.html
And latching valves (only take energy to change state--I think):
https://www.digcorp.com/professional-irrigation-products/lema-1600he-dc-solenoid-actuator-adapters
If you have a known sprinkler system and want to compare setting up a solar power system to run them, tell us how much energy per day (Watt*Hours or Amp*Hours @ 24 volts) you need.
Note--Check the power output from the 24 volt power cube... Is it 24 VDC or 24 VAC -- Many times, running an AC coil on DC can cause them to draw too much current and overheat. Also, the switching controls is usually different between AC vs DC loads.
Thank you for the reply. The system will be running 4 hours per day max.
Here are the specs : https://www.rainbird.com/sites/default/files/media/documents/2018-02/ts_ESP-LXBasic_en.pdf
Looks like 24v Ac. Maybe it's not even possible:/ -
Just to say there are a lot of pretty cost effective solar powered irrigation systems out there (many are 1 circuit systems--4x may not be cheap, or meet your needs for ease of programming):
https://www.amazon.com/s?k=solar+powered+irrigation+system+controllers
However, I am more than happy to give you an idea of what full sized AC solar power system may look like.
For a better estimate, get a Kill-a-Watt meter to figure out what the "real loads" are per day:
https://www.amazon.com/s?k=kill+a+watt+meter
First, lets assume worst case of 1,037 WH per day (this will actually give you more than enough power for some LED lighting, cell phone charging, laptop power, etc... -- My guess). So this is a good sized off grid power system for a cabin (no refrigerator).
First size the battery:- 1,037 WH per day * 1/0.85 AC inverter eff * 1/12 volt battery bank * 2 days storage * 0.50 max discharge = 406 AH @ 12 volts
The first choice you need to make... For base load design (24 hours per day x 7 days per week), I would make the battery bank (and supported load) 2x larger--But lets not bother now--I believe that would be terribly oversized for your needs and make this proposed system way too expensive... To continue
Next size the solar array to the size of the battery bank... 5% to 13% rate of charge suggested. 5% for weekend/summer usage, 10%+ for full time off grid:- 220 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 207 Watt solar array minimum
- 220 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 414 Watt array nominal
- 220 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 539 Watt array "cost effective" maximum
Saint George
Measured in kWh/m2/day onto a solar panel set at a 53° angle from vertical:
Assuming worst case (through winter), a December "break even" array (you may need a genset during bad weather to keep battery bank >50% state of charge):Jan Feb Mar Apr May Jun 4.34
4.65
5.96
6.36
6.49
6.64
Jul Aug Sep Oct Nov Dec 6.20
6.12
6.17
5.81
4.82
4.32
- 1,037 WH per day * 1/0.52 AC inverter off grid system eff * 1/4.32 hours of sun = 462 Watt array (Dec break even)
- 2 * 462 Watt array = 924 Watt array
- 924 Watt array * 0.77 panel+controller derarings * 1/14.5 volt charging = 49 Amp minimum MPPT controller
AC inverter:
https://www.solar-electric.com/samlex-pst-120-12-inverter.html
https://www.solar-electric.com/morningstar-si-300-115v-ul-inverter.html
Solar panels (3x in parallel):
https://www.solar-electric.com/axitec-ac-330p-156-72s-polycrystalline-solar-panel.html
The above is a very capable AC off grid power system, probably 3x larger than you would need (after you measure your irrigation controller energy usage)--But gives you the math behind the design, and some samples of good quality hardware and what questions you have to answer vs my guesstimates.
Way back before Moses.... I used to repair irrigation timers.
The vast majority of them were 24v. The devil is in the details... They ran on 24 volts AC. They would not run on DC.
The solenoids in the valves were 24vac as well. I imagine that they may work on DC but may have some heat issues.
Thanks for the info. The spinklers will be running for 4 hours per day max. Here are the specs:
Depending on how far you want to go down the Rabbit hole... Say the clock will run on battery (you could even bring out the coin cell connections to a little AA battery holder--Just find the operating voltage for those batteries--Depending on how long they can support the timer without power).
Use an AC inverter with a timer to only run 4 hours per day... 4x 7 VA (basically 7 Watt solenoids worst case), your energy needs could be down to:- 7 Watts * 4 solenoids * 4 hours per day + 6 Watt AC inverter Tare losses * 4 hours per day = 136 WH per day
- 136 WH per day * 1/0.85 AC inverter eff * 2 days storage * 1/0.50 max discharge * 2 days "base load" fudge factor 1/12 volt battery bus = 107 AH @ 12 volt battery bank
- 106 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.10 rate of charge = 200 Watt array "nominal"
- 136 WH per day * 1/0.52 off grid system eff * 1/4.32 hours of sun (Dec) = 60 Watt (Dec break even)
- 2 x 60 Watt panel for base load fudge factor = 120 Watt minimum (base on loads)
- 200 Watt based on battery charging > 120 Watt based on load => 200 Watt array minimum suggested for "reliable system"
This inverter is "Over Kill" for your needs, but it has a remote 12 volt on/off input (put a 12 volt timer that turns on when you need power), and it also has search mode (might be able to use this instead of timer--Inverter of "off" and only turns on when it sees > 6 Watt load on 12 VDC line--Aka, when timer turns on solenoids, inverter turns on).
Also, some sprinkler controllers have a remote on/off line to control a well pump... You could possibly connect this to the inverter's remote on/off input--And do without the second timer.
Not suggesting that this is "the way"--But it is an option that could meet your needs (cost, ease of maintenance, possible other local solar 12 VDC or 120 VAC uses--Like motion detector lighting, security alarm, laptop/tablet/phone charger, etc.).
-Bill "where there is a will, there is a way" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
I'd tried the battery / solar timers for a orchard, 6 stations. After several failures, and tree losses, I bit the bullet and dug a 1,000 feet of trench and ran power for a conventional irrigation timer. 5 years and no troubles since. (ok, one valve didn't drain and cold weather froze it) But no power / timer issues since using AC power.
