Did I kill my battery's?
machineman
machineman Solar Expert Posts: 129 ✭✭✭
Got a lot of snow last month at my remote cabin, and its been cloudy almost everyday. I have my magnum 24V system do a inverter LVD shut down at 23V. Panels covered in snow it shut down while i was away. Fine this happens in winter often but usually only a day or so. But it stayed off (i know because I can remote monitor if its up) for an entire month until my next visit. But I have my Davis weather station wired directly to the batterys so I dont lose data logging, constant current draw even with LVD, likely a bad idea in this case but never had this issue in the 10years since Ive been on this system. The 24V battery bank measured 3V!!!, So dead that the Xantrex XW60 charge controller wouldn't even fire up even if there was sun. Turned on the generator and charged it up, everything seemed back to normal. Turned gen off and they held. Got 440ah 6V eight GC batterys that are about 1 year old. Cant believe its survived that, permanent damage?
Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
  • Estragon
    If the battery cases didn't crack from frozen acid, you may have dodged the bullet. At low temps, sulfation happens much more slowly, so although they may not be as good as new, they may still have a decent service life.
    I'd check them over carefully for any signs of physical damage (eg bulging sides/posts, etc) though.
    Off-grid.
  • machineman
    They are in a half buried concrete shed so temps inside probably didn't get below freezing. I didn't notice any bulging and they still were full of water. Will do a detailed inspection next month when Im back. I built an arduino Ethernet controller that monitors the battery voltage, temp, and lots of other stuff so I can see whats happening remotely.
  • Estragon
    Something similar happened to me a few years ago, and the banks survived :-)
    I added small vertically mounted "winter float" arrays to avoid the problem in future.
    Off-grid.
  • Vic
    Personally,  would be astonished if the battery bank survived this.  -   3 V total for  a 24 V battery bank.  It is most likely that a number of cells were charged in reverse during the discharge.   This is almost always DEATH to those cells.
    Your LVD setting seems to be a good,   conservative value.
    A bit surprising that the Magnum would be able to charge the battery from the generator when the battery was at 3-ish V.
    Good luck with the battery bank,   Vic
  • softdown
    softdown Solar Expert Posts: 4,078 ✭✭✭✭
    3 volts in a 24 volt bank is scary. Let us know... S.G. is great but voltage works pretty well in my experience.
