Adjusting a AIMS Model PICOGLF60W24V240VS (6 Kw. 24Volts) Inverter to 50% DoD.
DoelO
Registered Users Posts: 2 ✭
Does anyone know how to adjust the inverter to avoid discharging the batteries lower than 50% DoD? Any one know where may I get a service manual for this inverter, I send a request to AIMS but so far no answer.
Best regards to all.
Don't think it's adjustable, what you may want to consider is the amount of energy this inverter needs just being on, without load, 76.8W that's 1.834 Kwh per day or 0.7Kwh in power save mode, seriously high. Do you need such a monster? Manual attached.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks for your information and the manual. Still no answer from AIMS.
