Can you safely use a motorbike 12V GEL battery in a PV system ?
Haglun
Registered Users Posts: 1 ✭
I am trying to set up a PV system that is as cheap as possible.
Eventually, my goal is to build IoT functionalities on top of it, using micro controllers. This way I will be able to monitor the PV, battery and control loads from a web app. I can do a few things in IoT, but I am a complete beginner in PV systems.
For the moment, the cheapest parts I found are the following:
- 18v, 85 watts solar panel
- 12v GEL battery (https://global.rakuten.com/en/store/bike-parts/item/12-09/)
- PWM charge controller (https://www.amazon.com/ALLPOWERS-Charger-Controller-Intelligent-Regulator/dp/B01MU0WMGT)
I suspect that the system will be pretty inefficient. I also know that the battery is insufficient to store all the electricity i can get from the solar panel. It is ok, my goal is to get a first experience and and the focus is on implementing IoT.
But I have the following question:
Is it safe to use the GEL battery to charge home appliances (using a 12v-5v DC converter) ?
I read that the GEL batteries are safe because they do not reject Hydrogen. But the battery manual says that the battery may reject hydrogen, and advises not to use it for any other purpose than engine starting.
Please tell me about any potential risks of using such a battery to store the PV generated electricity and charge small appliances (I will connect it to a 12 to 5V DC converter). Also, I have a lot to learn about PV systems, so I'm interested in any other remark you have.
Welcome to the forum
The Gel motorcycle battery is not well suited to the application as it is designed for starting primarily, to achieve the high current needed for the starter motor, the battery will have many thin plates to increase the total surface area within each cell, they also are immediately recharged by an alternator. Deep cycle batteries on the other hand have fewer thicker plates because higher current in short bursts are not a requirement, the thickness of the plates will have an effect on life expectancy as the plates are sacrificial loosing material as they age.
The materials used in the plates themselves will differ, most sealed motorcycle batteries are lead calicum, which provide properties needed for the application such as low self discharge, deep cycle commonly use pure lead, or an alloy of lead anttomony, lead carbon and other materials needed to suit the demands of long slow discharge low water consumption in the case of wet batteries, and so forth.
Would it be safe to use a motorcycle battery ? It probably is safe but the life expectancy will be dramatically reduced, perhaps lasting a few months, whereas the correct battery used within its limitations and properly charged may provide years of service.
Without trying to overwhelm you with all the details I've kept the focus on battery types, there is a wealth of information to be found from sites like this https://batteryuniversity.com/learn/article/lead_based_batteries an excellent starting point.
Always remember going cheap is a false economy, you'll go broke saving money.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
One thing to note is the DC voltage on the "12v" side can actually vary from <10v (battery essentially dead) to >15v (cool/cold battery in absorb charging cycle). You'll want to make sure the converters will provide stable 5v out with the variable input (or use a 12v voltage stabilizer in series ahead of the converter).Haglun said:...But I have the following question:
Is it safe to use the GEL battery to charge home appliances (using a 12v-5v DC converter) ?I read that the GEL batteries are safe because they do not reject Hydrogen. But the battery manual says that the battery may reject hydrogen, and advises not to use it for any other purpose than engine starting.
Also, I'm about to do something similar, and I'm a bit concerned about whether the switching DC converters will present any problems for SBCs (rPi zeros w in my case). If so, may have to add a linear regulator or something into the mix. Hopefully output caps on the SM converters alone will smooth enough for the SBCs.Off-grid.
The issue with most GEL batteries (at least those found in the USA) is that they can only be charged at a very low current (C/20 or 5% rate of charge).
If you charge a GEL battery at too high of rate (or too high of voltage, typically >14.2 volts @ 25C/75F), they start to gas and form permanent gas bubbles in the electrolyte GEL. Which permanently reduces the capacity of the battery.
For systems with Utility Power (24x7), you can take 10+ hours to recharge a 50% discharged battery bank. For solar, when you have ~6 hours or so of "useful" sun in a day (something like 9am to 3pm of full/direct sun on the panels)--It can take several days just to recharge the GEL battery.
If the system is only used (for example) on weekends or one day a week, you have the rest of the week to do 5% rate of charge--GEL could work OK.
If the system is used daily, you will never get the batteries back to fully charged (>~90% state of charge) and they will sulfate and die an early death.
GEL--Great for UPS functions (Float 24x7) and 20 minutes of high discharge. Just not great for day to day deep cycling and "short" charging cycles.
There are many european GEL batteries that seem to accept >5% rate of charge--But I do not know what is different and if they have other limitations (i.e., high rates of charge below 80% state of charge and 5% at over 80% state of charge).
