Wiring a DC fridge to a mini magnum panel
RonMarston
Registered Users Posts: 1 ✭
So I just had a solar power system installed.
I bought a DC fridge and freezer and have wired them to my Mini magnum panel.
I have no idea on how to wire the fridge and freezer to my panel
Please help
Please help
You will need a mini 1/2" wide DC circuit breaker of appropriate amperage which mounts on the DIN rail provided taking power from the battery positive bus, negative from battery negative bus. Disconnect all sources before working inside the enclosure, if you are uncertain seek some assistance from someone with experience. See page 54 of attached manual1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Welcome aboard. You've come to the right place for answers.RonMarston said:So I just had a solar power system installed.
Please help
