What happens to a panel with sun on it when not connected?
ollyomm
Registered Users Posts: 10 ✭✭
I do try to avoid this happening but Im curious as to what happens if anything?
Does it damage the panel in any way? overheating?
Eg, having mounted it on the roof and the delay in connecting and soldering cables
It's not something to be overly concerned with, electrically the will have no load, so no current flow and since they are designed to sit in the sun for 25+ years and still peform, negligible degredation will occur.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 232 Forum & Website
