How to connect panels to mppt
redunculous
redunculous Registered Users Posts: 22 ✭✭
Hi all
Finally purchased myself 2 x 100 watt panels and a recommended mppt controller for basic use and before they arrive I wanted to get some information on installation...
My panels come with MC4 connectors, I would like to combine the output of my panels so I am assuming I purchase the mc4 y / branch connectors?
Next my big question is, how to connect MC4 to my MPPT? I have this MPPT
https://www.amazon.com/dp/B01GMUPGX2/ref=twister_B01GMUPGW8?_encoding=UTF8&psc=1
Thank you for any help - its very much appreciated.
  • Photowhit
    Likely you should run 2 - 100 watt panels in series (+-+-) so you wouldn't need any connectors, in fact you likely would want voltage about 2x the system(battery) voltage.
    Most people figure out their distance from the panels to the charge controller and buy a single cable 2x as long, so if they will be 50 feet away, they would buy a single 100 foot cable with MC4 connectors, then cut the cable in half using one connector for + and one for -.
  • Lumisol
    Lumisol Registered Users Posts: 374 ✭✭✭
    Just pick up a package of MC4 connectors and a crimper and buy the length of 8AWG you need and put a connector on each of 2 wires, one male and one female. I did it that way and it worked fine.
    Strip the ends about 1/4 inch and put it in the appropriate input and tighten the screw.
  • redunculous
    Thank you for the responses - I didn't realise it was just simply 8awg crimped in there, I wasn't sure if it was some proprietary cable, going to make life a lot easier.
    Can I ask why you would wire them in series? I thought Parallel to get the amps up.
    I am using these to keep topped up 4 x trojan 105 6v batteries that are wired in series and in parallel. They are going on my sailboat - we don't use a great deal of power (we have replaced all bulbs with LED's and only have items that run occasionally such as fridge and freezer) so I figure if we can manage 8amps during the day from both panels combined we should be in great shape and be able to sufficiently charge the batteries daily after the night draw down.
  • redunculous
    So you wired yours in parallel and just had 2 x + and 2 x - crimped into single MC4's? Trying to find where I would purchase the connectors.
  • redunculous
    Forgot to ask, can I not just cut off the MC4 connectors that are on my wiring now and just use butt connectors to connect to a length of 8awg? I have asked the seller if this will void my warranty - if it doesn't then this should be the way to go right?
  • Estragon
    With an mppt controller you would normally wire panels in series so voltage is increased but current is kept low. The advantage to this is minimizing wire losses to the controller. The controller takes the wattage available and charges batteries at appropriate voltage (eg. 145 watts charging at 14.5v =10a). A pwm controller can only pass current through, so wiring in series wouldn't work well.
    On a sailboat you likely don't have much distance from panels to controller, so wire losses will be less of an issue. What may be an issue though is shading. Even a shadow from the backstay, for example, can reduce output a lot. In parallel the unshaded panel will produce normally. In series, the shaded panel will reduce power for the whole string.
    When solar panels get hot, their voltage is lower. This could be a problem for your mppt controller. They generally like an input voltage well above battery charging voltage. ~35v in series should work well. ~17ish may or may not.
    As for the MC4 connectors, the advantage is they're designed to make a weatherproof connection which can be disconnected and reconnected easily.
    Off-grid.
  • redunculous
    Great info, thank you - I will wire them in series, I had it in my brain that I would be pushing 24v to my 12v battery setup. The distance to my mppt is roughly 9ft so not too far. If I was to extend to 25ft would that be an issue as I would like to wire my mppt down to my nav desk rather then at the back of the boat in the cabin where it will be difficult to get to.
    Mc4 makes sense, will make up a set.
  • Estragon
    edited June 2017 #9
    The effect of distance on voltage is a function of wire size. There's a voltage drop chart in our host's learning center that you can use to look up various combinations of distance and wire size.
    I think using 8ga for 25' is probably ok, but best to check.
    Off-grid.
  • redunculous
    Thank you - I've decided to wire it to the rear cabin and run the remote to the nav desk. Saves me running cables there then back for the battery bank
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,198 ✭✭✭✭✭
    You really want to keep the distance between your controller and batteries as short as possible. Excessive voltage drop there will cause problems in what your charger "thinks" your batteries are at, and what they are actually at.
    As to another's suggestion to get wire, MC-4 ends and a crimping tool, unless you plan to be doing more "in the field" solar wiring, I would avoid spending the money on all this stuff. Buy a pre made length of PV wire w/ connectors and cut it in half, as Photowitt suggested.
  • Lumisol
    The extra money you'll pay for premade wires will pay you for the crimpers and still save money as well as giving you more flexibility in the future. Crimpers are cheap and if you decide to you can sell them again when you are done.
  • redunculous
    edited June 2017 #13
    Thanks for all the replies
    I have now installed the panels in series and wired up my mppt and remote. I ended up buying 8guage wire and crimping as I own the crimp tools anyway :)
  • Lumisol
    That's your best bet.
  • Photowhit
    Sorry I didn't get back to the thread. You did use wire designed for sun exposure? "Use 2" or solar wire? Other will quickly become brittle in the sun.
  • Solray
    Solray Registered Users Posts: 246 ✭✭✭
    edited June 2017 #16
    You may also use conduit to route the wires and protect them from the UV light. Conduit is a good idea even for wire rated for sun exposure as it offers protection from abrasion and cuts as well.
  • redunculous
    Thanks guys, sorry for the late response - we are now into our sailing trip
    We have the wires covered from the sun in conduit :)
  • Solray
