Generator charging hits float in 15min
just starting
Registered Users Posts: 235 ✭✭✭
Ok I have the magnum rd2824 and a magnum arc. I have a ryobi 2200 watt. I'm at 10200' so I lose 35 % power on the gen I have a.c. amps set at 7 . The temp sensor reads 4ºc different from xw 60-150 I have the custom battery setting on. Float is 27.8 asorb is 29.8 eq is set to 29.8 time is 0.1 hour float charging reads 35+amps
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Battery temp is 2C200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Batterys we're at 24.4v200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Switched to 8 amps. And holding 36 amps 27.9v float charging200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
JS are you stating that the battery is taking 1004.4 W of power (36A * 27.9V) in FLOAT? If so something is wrong... float should be at a fixed voltage and very low amps.
see figure 1 on this page... http://batteryuniversity.com/learn/article/charging_the_lead_acid_battery
Yes that's what I'm saying. The RD 2824 inverter charger kicks in to float very quick with a 5 amp 24 v load on the system.could it be the software in the arc and the inverter?200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
I know zip about your RD 2824 Inver/Charger.... have you tried Magnum support? My suspicion is , obviously the settings.... that setting the AC Amps to control the DC Amps is ???? to me...
Just got off with magnum. They said the resting volts is to high so when the charge starts the batterys go up in volts quick. So With low internal resistance the battery volts climb quickly so the charger goes to float and tries to hold voltage with amps. They said it's common and to try to start the gen at a lower voltage.they said if it were FLA it would not do that.200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
I can set in a.c. amps so the charger olny pulls 8 amps from the gen.200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
JS, so the charging was done on a resting battery at 24.4... I would have expected the quick rise in A if the battery was around 25 - 26V ie fully charged and resting but the Amps should drop wen it goes out of Absorb and into Float.
What are the preloaded charge profiles?
It's is pre loaded but I had to buy the controller to switch the charge profile it was set for a 600amp to a from the factory200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
I could change it from a multi stage charge to a constant current, constant voltage200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Its has a lot I'll put them up tonight200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
From what I've read its a common problem and when I called magnum tech support they confirmed it. I'm going to switch to outback soon. I think their charger has a little better software and you can use gen support.200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
