off grid solar system for deep well water pump
zeidyhall
Registered Users Posts: 1 ✭
Good afternoon, I am afraid I will have to ask that you speak as if I were a five year old, since i really know nothing about this subject. Precisely why I have the following questions:
I have a deep well 1.5HP water pump in a farm in Costa Rica. There is no electricity. I need to run the pump for at least 4 hours per day (we get plenty of sun for that and I have been quoted 3 250W panels a 400volts battery plus a 5000 watt inverter. I need the inverter to have the ability for both 220/120 since the pump is 220v but I want to plug a light bulb or two. Where can I find the right inverter or better yet, what should i be looking for in an inverter.
Welcome, having the make and model of that pump will go a long way to a correct answer form us...
A picture of the name plate works too...
Caution, do NOT buy anything till you get a complete answer.... also the make model of Panels inverter , battery
PS they left off a Charge Controller which you will need to charge those batteries... that are needed if you want an inverter...
There is a a second option for powering pumps. Basically:
Solar panels -> special AC inverter -> 3 phase motor -> pump
Some discussions about VFD (Variable Frequency Drives)... Basically a variable frequency inverter with (typically) three phase output. Used to soft start motors (handy for 3 phase well pumps, or pumps with well head starting capacitor) and can also turn an AC motor into a variable speed motor (very handy for pumping applications).
WELL PUMP and Inverter QUESTION
Wind/solar for large scale pumping etc (out of my depth!)
could use knowledge - using Gould jet pump - transfering from 230vAC to ? DC (new link/thread 10/27/2012)
Help required to design off grid system (information on possibilities to connect "standard VFDs direct to solar panels) (new link 1/13/2013)
If you can live with pumping only during the middle of the day, using solar + VFD + pump motor can be a really nice way to go. Finding a local person that knows where to find the "Solar VFD" and match it to the right pump may be difficult.
I have some clients in Playas Del Coco and if you are lucky your pump is a grundfos SQ or really lucky an SQE.
Short of these you will have to state a budget because if your pump is a standard deep well pump it is going be very expensive to compare with just running a generator for 4 hours as you stated.
Your parts list does not sound right, 400V for battery?"we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Figure a running load of 2500W, and a starting surge of 5-10 times that. The inverter, batteries and cables have to be able to supply the starting surge, or the inverter will shut down. OR look for a soft start pump. or a solar DC pump
- 232 Forum & Website
