12v led light opinions
All my light fixtures and in fact most of house wired for 12 volt. In past have used cfl bulbs with a 110/12v ballast for each bulb but as we know that has it's downsides. Now see 12v leds with Edison bases have really dropped in price and become a lot more available. Probably I'm the last one to become aware here.
So a lot of confusing choices, and hope those of you with experience here, especially recent, could chip in with consumer advice. Most expensive I see are an outfit, Independence electric in Canada with sinostar bulbs. A 10 watt is $27.50. claims 650 lumens.
Then you can get illumi 9 watt bulbs on Amazon for half that. These have no glass bulb, leds are exposed.
then are even cheaper ones, like $6.
No comparative data available as to what grade of leds are used or how well put together. No reputable solar energy like AW and sun sell these for some reason. Why not? Are they crap?
Off course am willing to pay more for higher efficiency per watt within reason and durability is very important. Thinking those illumi ones might be more durable because of how open they are but that's only if heat wears these out which not sure of. Anyone know? Especially if put in a semi enclosed fixture.
Even if had several lined up on table might be hard to judge how well made and measuring efficiency/lumen output tough so if anyone has tried these over time and has opinion please reveal.
We have a number of G4 LED's in our teardrop trailer and so far we have had no failures. However I wanted a couple for spares so found a 10 for $10 including shipping from China. Since I had them I decided to see what kind of abuse they would take. During bulk charge they would be getting 14.8V. I hooked up 2 12V batteries in series with a digital read out PWM to gradually increase voltage.
To make a log process short I gradually too the array up in voltage leaving it for an hour. It was not till I got as high as I could go at 23.5 volts that a couple of SMD's unsoldered themselves and fell off, the rest still work.
Hi Shadow,
That's very interesting, that you actually saw the direct damage from high voltage with your G4's. Wondered how that would manifest.
I'm only interested though in bulbs that have a regular screw on Edison base like standard incandescents. Don't think they made these 5-7 years ago, last time I looked.
Two types I mentioned do say 12-20 volts allowable operating range and I never equalize above 16.5 volts so good there. Did notice the real inexpensive ones on Amazon below the Illumi don't mention this, if that means anything.
Even those ones from Canadian dealer I mentioned are still made in China like the ones on Amazon and apparently sold through no other outlet so a mystery as to whether worth the high cost.
Lowes, home depo and auto parts stores have a selection of 12 volt LEDs.
Really? and with screw in base? You're lucky as I looked there in Oregon and nothing. Would of surprised me as not very many big box customers need a 12v light. Apparently not to many offgrid people either, who still just maybe run all inverter, judging from lack of offerings at solar dealers like AWS or commentary on blogs.
What state are you in Oil Pan?
You'd think these lights would be the cat's meow for the independent sorts. maybe they're junk -
I bought about 10 LED bulbs, E 27/26 screw-ins 12 volts 7 watts output which is about like a 60 watt incandescent.
I currently use 5 of them outside.
No problem so far in about 1 year use, used almost daily.
I got them of ebay and seem to be of good quality. I wish I could buy some with 10 watts which would be more like 75-100 watt bulb.
Here is the link where I got them from. http://www.ebay.com/itm/5-x-Super-Bright-High-Power-7W-12V-E27-Home-LED-Bulb-RV-Lights-Warm-White-E26-/281811961435?hash=item419d4d465b
I you are looking for 12 volt screw-in CFL bulbs, they make them. That is what I use before the LED's. But a CFL will consume twice the amps compare to those LED with the same light output.
At the auto parts stores its mostly wedge bases such as found on 194 bulbs.
Most of what the hardware stores had was wedge base and pin base like on the G4 LED retrofit.
You may be able to find some Edison base 12v LEDs at an RV store because I have seen Edison base 12 volt incandescent.
It looks like you will have to find some Edison base 12v RV LED replacements or switch over to something more automotive.
For what it's worth, I've ordered some MR16 GU10 24v DC LED track lights from Independence Electric Co (Canada) back in early 2015 and was very, very pleased with their customer service and support, but the track lights didn't end up working out for me given my setup (no A/C in central Texas).
I learned the hard way that some LEDs (MR16-3W-LED-WW-GU10-24V) are very susceptible to heat. I had the LED track lights mounted on the ceiling in our place in a track-lighting fixture (non-enclosed) that I had available. I installed three of the GU10 24v DC LED track bulbs and within a month or two there were two LED GU10 bulbs that were flickering. I immediately contacted Independence Electric Co (Canada) and they stepped up to the plate and suggested some configuration changes (ex. removal of a track-light fixture metal mesh shroud that allowed air to pass through but was still a barrier to air-flow and so was removed completely), as well as sending me three replacement GU10 24v DC LED bulbs free of charge, including free shipping from Canada (I'm in Texas) immediately. Long story short, the heat was still too much for these bulbs, even with some adjustments to the fixture. I didn't realize when I ordered them that 95 deg. F or above ambient temperature around the bulb is too much for these bulbs to handle and I guess the heat they generate on their own is enough to fry the driver (hence the flickering).
After I learned about the ambient temperature upper limit I decided to jump ship and went to "TheLEDLight.com" and found a more heat-resistant LED light fixture that can handle 24v DC. So far, after almost a year, they have been great and have a two year warranty!
Bottom line...Independence Electric Co (Canada) is a great company, as is TheLEDLight.com, and they both have a pretty good selection. Yes, you pay more for the bulbs, but I'm guessing you're paying for the quality. I don't doubt that if there was proper air flow and if the space was air conditioned that the LED bulbs would not have flickered...but I just got tired of dealing with flickering LEDs and went to some LED fixtures there were designed for higher ambient temperatures.
Hopefully this experience helps others out...I spent quite a bit of time trying to figure out how to obtain 24v DC LED lights for our off-grid place and I'm glad I learned what I learned. I would not hesitate to buy from Independence Electric Co or from TheLEDLight.com again!
100% Off-grid with: 8 Solarworld 275 Watt Panels, 8 Concorde SunXtender 405aH 6v AGM Batteries, MS-4448PAE 48v Inverter, MidNite Solar Classic 200 Charge Controller, 10,000 gallon rainwater collection system, etc. -
WiredCo has a nice assortment of LV LEDs, many of which have integral drivers so they can tolerate some voltage variation,
https://www.wiredco.com/LED_Lighting_Low_Voltage_s/1874.htm
Why would you convert your home from 120v AC to 12v DC?? You should use an inverter to change 12v DC to 120v AC for long wire transmission, then get some standard 120v LEDs. You probably think you are skipping the inverter losses, but your losses from voltage drop are probably far worse. Even just across a house.
All our lighting is all 24VDC led, and mostly home made. Why DC? Becasue our inverter gets switched off at night. And because the leds are 10V DC, why double convert?
I use this exact combination of parts: COB led, driver, heatsink.
http://www.ebay.com/itm/161404739591
http://www.ebay.com/itm/221225242717
http://www.ebay.com/itm/321757548210
Those drivers will run at either 12V or 24V, and are super efficient. The cob leds are nice and bright, good color and light distribution, not downlight focused.
Why make them myself? Becasue it allows you to seperate the driver from the heatsink (i put the driver in the ceiling rose fitting.) Putting the driver with its heat sensitive electrolytics right on top of the heatsink is just plain daft.
Total cost per 10W bulb? USD5.03
I'm not sure that's the OP's situation. But yes, if you don't have an A/C, heater, refrigerator, or freezer that needs the inverter to be on at night, that would be a case for a few low voltage lights.
How is each bulb just $5.03? You're first link for the heatsink is $17.90 alone. -
The OPs siuation is he has a low voltage system, right?
Look closer, thats a pack of 5 for USD15.90.
They make a great light, will run off anything from 11V to 35V... if you like to do things with your hands. Superior to anything you can buy under 100 bucks.
Ah, a five pack makes it a lot better price. I'm curious now, did you use existing in-wall wiring? Do you know the wire size?
I wired the place with twin core 4mm2 for all the lighting circuits. However as these lamps only draw 0.8A, youd need to do the voltage drop calcs to try to reuse your existing lighting circuits. In NZ lighting is generally 1.5mm2. Youd also want to label them clearly, the red and black twin core is pretty distinctive, and hard to confuse.
DC lighting is not for everyone, but seeing as LED looks to be here to stay, for new build smaller places with short runs, cabins and small houses, etc its worth looking at. We really enjoy it, the SO is into making light fittings out of antique bottles and all sorts of stuff.
Assuming a wire run with 5 of those bulbs, just because designing less is silly...
1.5mm / 12v / 50ft / 4A = 78% power delivery
4.0mm / 24v / 50ft / 4A = 95.7% power delivery
So you're system, zoneBlue, is excellent. A 12v system on standard 18ga wires is sub-par. -
But wait... it gets better. First, i run two leds per driver (why curse the dark), its a 0.9A constant current driver, so 10V+10V =20V, leaving just 6V for the driver to deal with (and thus running the led at 9W helps to prolong life). The driver thus runs barely warm to the touch. Second to simplify my description, the 4mm2 runs are just the legs which feed off 6AWG trunk lines. Third, the longest dimension of our house is like 25ft, so total wire length is quite a bit less than 50ft.
Theres quite a bit of other DC stuff here too. Theres 8 USB ports for phones and other gadgets, a 12V DC converter for sundry items, a 19V DC converter for the laptops, and the file server. The power monitoring system runs off its own 5V DC converter. Oh and the fridge, 24V danfoss model.
That sounds like a well designed setup. Wires do end up surprisingly long after they navigate the walls and ceilings though. It sounds like you built it though, so you would know.
Josh K--Regarding your query as to why don't run 120vac leds and rest of house off an inverter.
This off grid home built from scratch and put emphasis on resilience with 2 different wired circuits Ac and Dc. use top of line 12 volt Outback for shop and kitchen tools but still, everything fails eventually and big hassle so run necessary basics lights, fridge, water pumping on dc. Worth it to me to pay more in copper. And this done back in the day when copper was lot cheaper. Think 4/0 for basic house skeleton and out to well etc was $1 a foot so volt loss acceptable 1-2%. Just seemed stupid having an inverter wake up just to turn one or a few lights. I know inverters lot cheaper now but maybe not the real tough ones so much.
Always ran the cfl bulbs that came with integral but replaceable 12v/110v ballast which were fairly energy cheap(but not as) but bulbs wore out quick if you turned on for short periods. -
Thanks Johann-Have written the ebay guy but hasn't answered. Have you run much at high ambient temps or voltages and how high if so?
Great Info Hill Country! Wasn't previously really thinking about ambient heat. Just concerned with internally generated heat. Where did you get figure of 95 degrees?
So curious why you chose the MR bulb type instead of the type with incandescent type bulb they also carry like this
http://www.led-cfl-lighthouse.com/product/Bulb-10W-LED-12V-PW%20G60S. or like what Johann bought on ebay
Is there an advantage to the Mr type for you?
Seems they do have an adaptor to switch MR type to edison
mainly though wondering what you chose at ledlight.com that you found was better with high heat? can't find much offered there. Have you tried it much under the same high heat condition as previous test without failure?
So far this week have received two bulbs. One off Amazon-12vmonster 9 watt white light is a kind of cylinder with exposed leds. tested with different voltages but still only does 6.2 watts. seems cheaply made. Another-- "Chichin" is a small G50 size bulb which says 7 watt on it but puts out only 5 from 12.8v-15.5v. But, go to there own site and can buy 10 for $70 and you could double up in fixtures.
Will try Canadian guys above and maybe the ebay one. would pay 25 if knew it would really last better but will take owning for long time and using in high room heat or while equalizing above 16v a lot to know what is best as no manufacturer is giving any specifics.
hopefully people will continue to chip in with their experience as time goes by
Zoneblue-- this over my head at moment but will try to figure it. Don't even know yet what a driver does but even so it does seem dumb to put right on heat sink and is surprising that they do. Geez, no or minimal insulation?
Could you maybe provide a photo of one of these put together? Maybe it's the only way but don't imagine you'd be able to mount in regular light fixture tho that's not a deal killer. Real issue might just be, as usual, the time to figure it and build several and mount them all. Until I retire that is. -
larcal...no problem, my pleasure. I've been helped by the NAWS forum many, many times and wanted to share my experience too.
In regards to your questions:
1) The 95 degree F. ambient air temperature figure is simply an estimate by me. When working with Independence Elec. Co. (Canada) on troubleshooting the flickering LEDs, they said that 90 deg. F ambient temperature was too hot for these LEDs (I wish I had known that when I bought them or I wouldn't have bought them). I estimated our ambient air temperature near the surface of the ceiling at about 95 deg. F because I held a thermometer up where the bulbs were mounted near the ceiling (when the bulbs were off) in the summer. The ceiling height there where the bulbs were mounted was probably about 10 feet high. Like I mentioned, our off-grid place (single story with a single pitch roof) is not air-conditioned and during the summer, in Texas, especially in the late afternoon, the air temperature right near the ceiling is definitely above 90 deg. F. We designed our place to passive solar with our place oriented to the southeast to catch the prevailing summer breeze, as well as have venting windows at the high side of the single pitch roof, plus we have ceiling fans and do the whole leave the windows open at night when it's cool and then shut the house up during the day to preserve the cool(er) air. It never gets above about 80 deg. F at normal people height, but because we have higher ceilings, the temperature near the ceiling is relatively high compared to a house with air conditioning.
2) The reason I initially chose the MR style bulbs is that I already had a track light fixture that accepted GU10 style connections...the track light fixture I had was the Lithonia 3 track light fixture designed for AC current with 50 watt halogen bulbs (see http://www.lithonia.com/commercial/3-light+linear+fixed+mesh+back+lamp+halogen+kit.html#.VwaRthwupms ). I simply removed the "dimmer" switch and used the existing wiring and connected it to our 24vDC circuit in our house (I have a 48vDC to 24vDC converter because there weren't too many DC appliances available that can run off of 48v DC nominal current). So the voltage is very much stable and regulated at about 28vDC (I can set it with a small adjustment to whatever I want around 24vDC).
3) I decided to forgo the track light approach and go with a 'flush-mount' low profile LED fixture from TheLEDlight.com. It is good to something like 150 deg. F ambient air temperature. Please see: http://www.theledlight.com/ledFlushMountLights.html They sell it as a 24vDC using a supplied driver, which is separate from the LED light fixture so the driver is not getting heated by the LED lights (brilliant!). I have been using this 7 inch flush mount low profile LED fixture from TheLEDlight.com for awhile now under the same conditions as the flickering GU10 track light LEDs that flickered and we have not had a problem...no flickering!!
Overall...the moral of the story is...it depends. You need to consider the ambient air temperature, especially with LED lights that have the driver integrated with the bulb. Many times the manufacturer will specify whether the LED light fixture can be enclosed or not...this has to do with the heat they create and whether or not they fry themselves up. In my case, the ambient air temperature around the GU10 bulbs was just too high...
Hope this helps!
Larcell, at the time(2012),i bought one of every DC led bulb i could lay my hands on, and wasnt really happy with them. As you found exagerated wattage was and still is common. However since that time there are now some very good AC leds like the phillips ones, DC leds are still by in large cheaply made, but they are improving.
For instance I bought some of these MR16s recently and (for low wattage applications) am generally happy with the performance.
http://www.ebay.com/itm/High-Power-Cree-E27-MR16-GU10-LED-COB-Spotlight-Downlight-Bulbs-Lamps-6W-9W-12W-/261532368087 (3W mislabelled 6W, 9W actually 6W etc, but basically a comercial version of my design)
And these G4s (G4 can be fudged to fit MR16) are also pretty cute,if only practical in the lower wattages, being without heatsinkng.
http://www.ebay.com/itm/Mini-G4-G9-Dimmable-Led-Spotlight-Bulb-3W-5W-6W-7W-9W-Light-3014-SMD-COB-Lamp-/121644368293
Im going to use them in a glass candellabra kind of thing she found. They come with two types of in built drivers, a simple 12V rectifier plus resister, and the proper switching driver, You can tell them apart by the presence of a chip and inductor.
For my ones. The driver is a little circuit that turns the input voltage into a fixed current, If you dont do this the led will either not run efficently or will blow up. All you need to do is solder 4 wires, and screw 4 screws. But you are right they wont fit any std light socket, however a light socket stems from the days when you had to replace the bulbs every year or so, tungsten, right.? So far i havent had any problem converting any of the light fittings that the woman has thrown at me, and it was kind of satisfying to upgrade them to modern technology, 90 lumens per watt goodness, some pics here http://zoneblue.org/cms/page.php?view=led-lighting
Note that i now use one led per heatsink because i was originally using intel ones, but the ebay ones are smaller but much cheaper. Also 20W was a bit too much even for the intel ones, as they ran quite hot.
Thats probably more than anyone wants to know about DC lighting, so ill leave it there. Ah yeah. For now...
If you want "too much information" about smaller LEDs, batteries, and Flashlights, this is a good place to start:
http://www.candlepowerforums.com/vb/forum.php
Sorry for the late response.larcal said:Thanks Johann-Have written the ebay guy but hasn't answered. Have you run much at high ambient temps or voltages and how high if so?
High temperatures exposed around here is around 100F in the summer, later in the night it will cool down more ...like 90F. My LED's are not exposed to a constant high temperature since they are currently used outside at the wood storage area and temperatures are fluctuating between mornings and evening and the seasons.
The LED will turn off at about 6 volts and I had them run at 20 volts panel voltage today, but only for about 20 minutes so i can not tell you how long they would last with that high of an voltage. Remember that those are 12 volt Led light-bulbs and higher voltages could shorten the life.
Cool. How do you get the 6v and 20v? Some kind of controller taking 120ac and converting to range of dcv?Johann said:
Wonder if running these in a room at 75-80F a lot causes a short life. If that's okay you'd be good for 8 months anyway and could switch back to ballasted cfl in the deep hot summer with no AC when even at night inside rooms can be 95F but you still need light. -
The key to determining is a "12V" LED will run at other voltages is to see what the driver is comprised of. Some have constant current drivers in which case they are more likely to run at higher voltages, being primary limited by the upper limit of the chip concerned and the voltage rating of the input smoothing capacitor. Others on the other hand just have a bridge rectifer and a limiting resister. These you must NOT run above their nominal rated voltage. They MAY be ok at 14.8V for a 12V bulb (or they may not!).
I was testing and trying to rescue a complete dead bad battery that was sitting around for 6-9 month.larcal said:
I was trying to use my el cheapo china made controller to charge it, but that controller did not see the battery at all since the battery was dead and since the controller did not turn on . So this cheap controller gets the operating power from the battery and that was interesting.
So I hooked the 12 volt nominal solar panels straight to the battery and that showed 20 volt on the meter and my chinese controller came on and showed the same voltage since the chinese controller was still hooked up to the battery power. I was trying to put a load on the panels to lower the voltage, so I turned my LED lights on which I left on. With bright sun light and being cool here right now I could not drop the voltage with those 5 bulbs at all, but the bulbs did not burn up.
After about 20-30 minutes I tuned my breaker to the solar panels off and I could see the battery voltage dropped on that dead battery. At about 8 volts my chinese controller stopped displaying anything and went dead and the light bulbs where still on, at about 6 volts the light bulbs turned off also.
- 231 Forum & Website
