solar panel for 305 gallon aquaponic hoop house
5thgradeotg
Registered Users Posts: 1 ✭
I am a 5th grade teacher and am teaching off the grid sustainability, what are the specific necessities (size of solar panel, voltage/watts, inverter, battery etc) to run the water pump 24 hours a day?
Sort of like asking "how much electricity does it take to run a light bulb?" It depends on the lightbulb.
Welcome to the forum,
The answer to your question depends on the pump. First thing to figure out is how many watts does the pump draw, and how many hours a day is it pumping? Multiply those two numbers and you get watthours. Once we have a daily watthour total, the system design is straight forward.
Generally, pumps that draw more watts are able to move more gallons per minute and/or provide the water at higher pressure.
--vtMaps
Phew! when I read the title alone I thought you wanted to use the PV to create the heat for the house... Possible but not likely... How WILL you be generating the heat for that system?
As the folks above have said, it really is important to know your needs and get the most efficient pump(s) you can.
This website has a lot of detail information as he spent a few years installing/upgrading/fixing his system (relatively small system):
http://www.arttec.net/Solar/BarnHeat.html
And this one is a bit more low tech home made heating system. (but system is installed in snow belt)
And for details, there are some DC pumps out there. Some are "brushless" (electronic commutation) and others are "brushed":
http://www.thesolar.biz/dc_hot_water_circulating_pumps.htm
And, the question of how much pumping you need. The above pumps only will pump 10-20 inches of water, and need only 10-20 watts or so of power. If you are using solar panels to heat, then you may get away with a solar panel directly powering a water pump (no battery--Least maintenance, least costs).
However, if you need a 24x7 water pump. And say it is a 100 Watt pump (normal larger hydronic heating system), for example, this is how I would suggest you would do the calculations for a full AC / Battery Based / Off Grid system. Your needs will probably be different, but it gives you an idea about the math.
Example system:
24 hour per day, 2 days of backup power (no sun), 50% maximum battery discharge, flooded cell battery, Long Beach California, 100 Watt average AC power.
First size the battery bank:- 100 Watts * 1/24 volt battery bank * 24 hours per day * 1/0.85 AC Inverter eff * 2 days no sun * 1/0.50 max battery discharge = 471 AH battery bank (about 4x 6 volt @ 220 AH golf cart batteries)
- 471 AH * 29 volts charging * 1/0.77 solar panel+charge controller derating * 0.05 rate of charge = 887 Watt array minimum (weekend/seasonal system)
- 471 AH * 29 volts charging * 1/0.77 solar panel+charge controller derating * 0.10 rate of charge =1,774 Watt array nominal (full time off grid)
- 471 AH * 29 volts charging * 1/0.77 solar panel+charge controller derating * 0.13 rate of charge =2,306 Watt array "cost effective" maximum array
http://solarelectricityhandbook.com/solar-irradiance.htmlSanta Ana
Measured in kWh/m2/day onto a solar panel set at a 56° angle from Vertical:
There is always the question of how much sun in the winter---Southern California is not too bad... Other places may be less than 2 hours of sun per day in the winter. For this setup, assume that you will use a backup genset during multi-day stormy weather. And in this case use 4.50 Hours of sun (long term December Average):Jan Feb Mar Apr May Jun 4.54
4.95
5.84
6.43
6.15
6.10
Jul Aug Sep Oct Nov Dec 6.21
6.30
6.05
5.43
5.01
4.50
- 100 Watts * 24 hours per day * 1/0.52 off grid system efficiency * 1/4.50 hours of sun = 1,026 Watt array minimum
Your questions.
