fusing battery
javadz
Registered Users Posts: 20 ✭
hello alls
can i use a solar Gpv fuse for batery protection ?(since the Gpv Solar fuse are for continus current)
also, can i use a dc breaker to protect batterie but did the dc breaker can let the current go in the two dirrection (charge and disharge)
You can certainly use DC breakers, be sure as you suggest, that you get un-polarized breakers. Northern Arizona Wind and Sun (NAWS) offers a good selection!
GPV fuses look to be lower amperage than you would typically use for batteries, but if they are in the size you need and rated for DC, you should be good-to-go.
I prefer to use breakers as fuses can fail do to volt drop heating between the fuse and holder.
