Relay question
plexed
Registered Users Posts: 14 ✭
Looking for an inexpensive relay for a 12VDC motor driver with about a 10A capacity. Looked at the LY series (general purpose relays) and SSRs fronm Teledyne. The Teledyne ST24D25-16 looked nice because it has a built-in MOV and was easy to mount. Looking for something I can mount on a wood panel. Also, can the Teledyne switch DC loads even though it is rated for AC?
Any other suggestions?
Re: Relay question
I believe these are for controlling AC voltage only, to turn off, the main AC power needs to cross zero volts, and then the triac/SCR will not fire.
What you want to control DC, is a FET or MOSFET switch.
http://www.mouser.com/Search/ProductDetail.aspx?qs=QXs58j9tPLsD6leT1wsTQA%3d%3d
(may not be a proper part for your application)
is result of a quick search, maybe Digikey has something better.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Relay question
Look for a fan/fog lamp relay at an auto parts store. Most will have a tab to mount the relay. -
Re: Relay question
I know radio shack carries a 30 amp 12v relay as well. It's sealed and has a mounting hole built right in as well.3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI
