Volts system differences
I was looking at the Conenergy Solar Force Piston Pumps. I would need one operating straight from PV solar panels. I noted they had the pumps in 12V for $1787.00, 24V for $1806.00, and 48V for $1696.00.
How do I decide which voltage of sytem I want? My panels will have to be 150 - 160 feet from my pump. Would I want a higher voltage system because of the length between the two? What are the factors I should be looking at to decide what voltage of a system I need?
It also surprised me that the 48 volt pump was the cheapest. I am sure there is a reason for it.
Thanks in advance for any input....
Re: Volts system differences
Double the volts, halve the amps. At the distance that you mention, I would go with the highest voltage possible. Reduces the wire size, line loss.
Tony -
Less copper involved at higher voltage ??Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
