Suggestion on this setup for a complete beginner.
hochin
hochin Registered Users Posts: 2
Hi all!
So I'm planning on making a move soon to an otg farm here in Hawaii and was wondering if this setup would be efficient enough to power a laptop and a few other gadgets. Would I need to purchase any other type of connection cables? Which parts would I need to keep safe from wet weather? Sorry I'm such a complete beginner to this kind of thing but any kind of tip would be greatly appreciated.
www.amazon.com/Renogy-100W-Mono-Starter-Kit/dp/B00BFCNFRM/ref=sr_1_5?ie=UTF8&qid=1421026809&sr=8-5&keywords=solar+generator
www.amazon.com/DEEPCYCLE-SOLAR-ENERGY-STORAGE-BATTERY/dp/B008D5YG3G/ref=pd_bxgy_lg_img_z
www.amazon.com/BESTEK®-Inverter-Notebook-cigarette-MRI10011/dp/B007SLDDHQ/ref=pd_bxgy_lg_img_y
    Re: Suggestion on this setup for a complete beginner.
    Welcome to the forum Hochin!
    More or less, the chances that you will be happy with one each of the above--Is not very high.
    The right way to start is to use a Kill-a-Watt type meter (for AC) or A DC Amp*Hour/Watt*Hour meter and measure your loads.
    Once we know the loads and better understand your needs, we can start some calculations.
    However, I can give you some round numbers that will be a good start. A 1 kWatt*Hour per day system will usually power a laptop, printer, cell phone/networking, some lights (or 1,000 Watt*Hours -- Or around 100 Amp*Hours @ 12 volts DC).
    If it is only 8 hours on a laptop and charging your cells phone, you might do OK with 500 WH per day. I will do a 1,000 WH per system calculation, but you can basically divide everything by 1/2 for a 500 WH per day system.
    First, the battery bank. Assume you will be using an AC inverter (300 Watt MorningStar TSW 12 VDC inverter is a very sweet unit). Assuming 2 days of "no sun" storage and 50% maximum discharge (longer battery life):
    • 1,000 WH per day * 1/0.85 AC inverter eff * 1/12 volt battery bank * 2 days storage * 1/0.50 max discharge = 392 AH @ 12 volt battery bank
    The above battery bank is roughly 4x 6 volt @ 200 AH "golf cart" batteries. If you are only using power during sunny days, and don't need more than 1 day of backup, you could use a smaller battery bank.
    To size the solar array, we have two calculations to make. One based on charging the battery bank with 5% to 13% rate of charge... And the second based on power used and how much sun you have.
    First, charging rate...5% rate of charge is good for weekends and seasonal usage. 10%-13%+ is good for full time off grid usage:
    • 392 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.05 rate of charge = 369 Watt minimum array
    • 392 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.10 rate of charge = 738 Watt nominal array
    • 392 AH * 14.5 volts charging * 1/0.77 panel+controller derating * 0.13 rate of charge = 960 Watt "cost effective" maximum array
    Next, sizing based on the available sun... Using PV Watts for a fixed array, tilted to 22 degrees from horizontal for Lihue Hawaii:
    Month
    Solar Radiation
    (kWh/m2/day)
    1
    4.79
    2
    5.17
    3
    5.08
    4
    5.48
    5
    5.31
    6
    5.65
    7
    5.48
    8
    5.76
    9
    5.91
    10
    5.40
    11
    4.44
    12
    4.43
    Year
    5.24
    Use 4.43 hours of sun minimum:
    • 1,000 WH per day * 1/0.52 end to end system eff * 1/4.43 hours of sun per day = 434 Watt array minimum based on load...
    So, depending on size of the battery bank and the actual amount of power per day you want (knowing that you should not plan on using 100% of the predicted solar power per day, but something like 65 to 75% per day--And good days you can use more).
    For a 1,000 WH per day 120 VAC system, with 2 days of storage--A 434 Watt to 738 Watt solar array is certainly justifiable.
    If you have multiple days of bad weather--Then you should also have a small genset.
    Anyway... A starting point for discussion.
  • westbranch
    I agree with Bill, you probably won't be happy with that package.
    Quick facts, battery has capacity to deliver ~200 watt hrs of power, ie 200Watts for 1.1 hr. You do not need an inverter that can deliver up to 5 times that. The no load draw will eat into that 200Wh pretty fast...
    The Charger is a low cost model, not recommended.
    PV panel, average quality. Do not consider any value for the warranty as some of the best manufacturers have disappeared into bankruptcy...
    Do some research and ask questions here and you can get some good quality equipment for about the same money...
    hth
    West Chilcotin, BC, Canada
  • hochin
    I'd really just be living in a very small one room cabin with the laptop on only for a few hours and the rest of the time charging smaller devices such as a cellphone, tablet, 2 500mA speakers for music. With a small budget around $330 too...
    Just... wow, yes I really do need to get some research in as this seems like a whole other language to me, but thank you guys very much for the starting info and tips, I will take note of it.
