"New" refrigerators and modified sine inverters
706jim
Solar Expert Posts: 529 ✭✭✭✭
In the works for the future is an electric fridge for my island cabin.
I use propane now, but with that fuel comes a number of issues including flame going out, carbon etc.
In the experience of posters here, will a new Samsung fridge run ok off of modified sine power or are there problems with the electronics controlling the unit?
While this might seem an odd question, a "new" electric blanket will not run from this power source due to the electronic thermostat while an older one would have no problem at all.
Just hoping to be able to keep my wonderful Trace DR1500 in service for as long as possible. (20 trouble free years so far!)
Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
Re: "New" refrigerators and modified sine inverters
Jim, at 20 years you are 'skating on thin ice' I would buy a replacement now :cool: and wait for the inevitable
then just swap the old faithful out... like an old dog, it's time is running out...
Oh, go TSW solves a lot of potential issues up front.
My personal guess. With electronic power supplies that are power factor corrected (have PF>0.95),they probably will work ok on msw. And a second check is measure the PF on the msw inverter. A kill a Watt meter usually works ok.
If the PF falls on the msw inverter below 0.95pf, then I would not run on msw.
But as above, tsw or psw is much better.
I agree with BB and will add a guess that most new higher power inverter based devices (like a refrigerator) are power factor corrected. A low load like a controller for a blanket (not the entire blanket) probably wouldn't be.I am available for custom hardware/firmware development
