sunsavermppt controller,view in android on my tablet
jeffhawaii
Registered Users Posts: 1
Hi I would like to use my android tablet to monitor my controller.Is there any program out there for this application? thank you .aloha jeffhawaii
Re: sunsavermppt controller,view in android on my tablet
Midnight has an app to monitor it's Classic series.
Morningstar MPPT 60 has an internal web server, and any browser looking at it's IP address, can see it.
But otherwise, most morningstar stuff wants serial or usb connectionsPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I don't know anything about Android or the capabilities of an Android tablet to connect to devices. One option to monitor your SunSaver MPPT using your Android tablet would be to setup a small computer like a Sheevaplug, Raspberry Pi, or Beaglebone to capture the data from the SunSaver and present it on a web page. If your Android tablet can directly connect to a USB device and you have some programming ability on Android, you could modify software to pull the data from the SunSaver when connected.
I have a SheevaPlug that captures the data from my two SunSaver MPPTs and a SureSine-300 inverter every 5 minutes and posts the data on a web site I can view from any Internet-connected device. See: http://westyd1982.wordpress.com/ for the software examples.jeffhawaii wrote: »Hi I would like to use my android tablet to monitor my controller.Is there any program out there for this application? thank you .aloha jeffhawaii
