Cheap 300 AMP Breaker
CRMW
Registered Users Posts: 7 ✭
In my quest for fuses & disconnects, for my RV system I came upon this breaker:
http://cgi.ebay.com/CIRCUIT-BREAKER-300-AMP-12V-SELF-TEST-new-PS82-300A_W0QQitemZ140242285164QQihZ004QQcategoryZ32809QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
I was looking for a 300 amp fuse between my inverter and battery bank. Is there some reason that this breaker would not work. I think its primary function is for car audio, but it is rated for 300 amps & 12v.
Chris
Chris
Re: Cheap 300 AMP Breaker
The self-reset might worry me.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Good point, I'll send them an e-mail and ask the question. I assumed it was a self test, (the button to trip the breaker) and a manual reset (the lever to reset the breaker).
Chris
- 234 Forum & Website
