Battery Cable size question
scheek
Registered Users Posts: 26 ✭✭
I have been advised to use 4/0 battery cable with my 24v battery banks. I have now realized that I have a big supply of line wire (type used between street poles) on hand. I have looked at it closely and I have two sizes. The smaller within the insulation is 1/4" with 7 aluminum stranded wires with in it. The larger wire is nearly 3/8- 1/2 in dia within the insulation with nearly 24 strands of aluminum wire.
I don't know the formulas to calculate the ?/0 size. What /0 is this possibly? Is this something I can use to save money on my battery cable network. if so, I make my own up?
Any help would be appreciated.
Re: Battery Cable size question
Here are the pics of the wire
Attachment not found.Attachment not found. -
It's aluminium; don't use it.
Aluminium has problems with connections; they corrode easily unless the connections are made just right. It also does not conduct as much current for the same diameter as copper. 4/0 copper, for example has a diameter of 0.46 inches and can handle 300 Amps. Aluminium would have to be about twice the size to handle the same amount of current. -
That's hard to tell. You need to measure the diameter.
This is a rigid cable. It's very hard to work with it. Usually batteries are wired with soft welding cables. -
Dang! Well, what's a little more money. I've about got this thing whipped anyway now. Any tips on saving money on the 4/0 wire and cable ends? I've heard welding wire does a good job. I don't mind making up my own. Where is a good source for this and any advise?
Thanks. -
Check out your local welding supplies outlets and compare prices!
Wind-sun has good prices for the lugs, and I think they have pre-made wires too. And UL rated Locomotive Cable (fancy welding cable)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
