Making use of a 16 Watt Panel
Hi All,
I've been given a 16 watt unisolar panel. It says max output is 30 volts and 1.5 amps. I would like to use it to power a 12 volt device that I have. I was wondering if there is a way to do this without having a battery in the mix. In other words I want to run the panel through some kind of device (voltage regulator?) to convert it to 12 volts and run the device directly off the resulator's output. Is there a way to do this?
Thanks ahead of time!
Re: Making use of a 16 Watt Panel
Yes it can be done. How much current dose the device need? -
And is there a start up surge needed by this device? Or momentary surges while in operation?
May we ask what the device is? Knowing that, would reduce the guesswork on our part.
Cheers
Wayne -
The simple method is to use a common 3 terminal linear voltage regulator, with a heat sink.
You will loose a lot of power to the heat sink (about 8 of your 16 watts) but you will get the desired voltage for less than $10 (regulator IC, heat sink, caps, proto-box). The more efficient method, with a DC-DC regulator, will be much more expensive.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
