Using 2 inverters in RV
simmtron
Solar Expert Posts: 87 ✭✭✭
This is my situation, we live in our motorhome in Mexico and have a solar system set up with 500 watts of panel, a Xantrex 2000 watt 458 series modified wave inverter and 4 T105 batteries. What I would like to do is use a 650 watt pure sine wave inverter I have by attaching it to the batteries and plugging the shore power extension into it. The Xantrex would still be hooked up but invert and charge function off. I would set the shore power share setting to 5 amps in case for some reason the Xantrex was powered up and tried to charge the batteries from the 650 watt inverter. I do not want to disconnect the Xantrex from the system as I use the battery charge function of it sometimes with my Yamaha generator. I would shut off the 650 watt inverter when charging and change the shore power share setting back to 30 amps. Can anyone see a problem here? 650 watts is plenty for my needs.
Re: Using 2 inverters in RV
Why don't you put the output of the 458 inverter on a range plug and just plug the inverter in you plan on using ?? That way there never a chance they would ever cross their outputs. I usually setup both inputs / outputs that way, so I can bypass the inverter or plug a spare in at any time.This is my situation, we live in our motorhome in Mexico and have a solar system set up with 500 watts of panel, a Xantrex 2000 watt 458 series modified wave inverter and 4 T105 batteries. What I would like to do is use a 650 watt pure sine wave inverter I have by attaching it to the batteries and plugging the shore power extension into it. The Xantrex would still be hooked up but invert and charge function off. I would set the shore power share setting to 5 amps in case for some reason the Xantrex was powered up and tried to charge the batteries from the 650 watt inverter. I do not want to disconnect the Xantrex from the system as I use the battery charge function of it sometimes with my Yamaha generator. I would shut off the 650 watt inverter when charging and change the shore power share setting back to 30 amps. Can anyone see a problem here? 650 watts is plenty for my needs.
I never trust myself to forget and you'll blow up both inverters. This way you plug one or the other. -
Great idea, I did ponder doing something like that, probably safer too -
You could actually leave the input of the 458 hooked up and still charge with it. The output is the real problem.Great idea, I did ponder doing something like that, probably safer too
