System Monitors
Of these two which one is the better one for off grid? Or which one do you like the best. I have a 24 volt system.
The OutBack Power Systems FLEXnet or the Xantrex TM500A Battery System Monitor. I have a MX 60 and a Xantrex 2440 inverter
Thanks Brian
Thanks Brian
Re: System Monitors
Brian I believe the outback flexnet requires the Outback mate to display the readings and thus you really need a complete outback inverter system.
I use the Xantrex XBM with optional software interface I think it is very good ,it is generic in its use and can go from system to system.
There are other options out there but I let those who have first hand knowledge of them give you there opinions.
HTH -
Re: System Monitors
Nigtomdaw is correct. The FlexNet DC works great but to be any kind of useful you need a hub and mate to display the readings. If you have or plan to have an Outback system with a mate and hub I would get The FNDC. If not then get a standalone monitor.
