Inverter/Chargers
intruderii
Registered Users Posts: 1
I've been looking at Inverter/Chargers lately, and it seems that little is said about the charger. Am I correct in assuming they're typically not state of the art MPPT chargers?
Re: Inverter/Chargers
Inverter/chargers don't need MPPT, since their voltage comes from the "grid", at a steady 240 or 120V
What is important converting from AC to DC, is the POWER FACTOR of the charger section. A good power factor (perfect is 1.0) of .9 will be more efficient running from your generator, than a charger with a .6 PF, which will require a larger generator to drive it.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
