Service panel upgrade or sub-panel
newenergy
Solar Expert Posts: 291 ✭✭✭✭✭✭
A 100 amp service panel is full. I'm hoping to install a 3kw system. Cost is a bit of an issue. The clients are pretty conservative on their power use.
A service upgrade is probably best, but it has also been suggested that installing a sub-panel and using it for a larger circuit from the house (to free a space for the sub-panel feed) and the breaker that leads to the inverter would be acceptable.
I'm leaning towards the service upgrade and will probably do it even if the extra cost comes out of my profit, but what do you think?
Re: Service panel upgrade or sub-panel
Go with the upgrade. It will have to be done sooner or later, plus gives one less item to fail inspection. -
1) what does code require in your area?
2) whats the difficulty in changing the panel (brick, stucco, wood ?)
3) what does code say about a sub panel - permissible ?
I'd for sure, wire the inverter into the main panel, and split loads off to a sub-panel.
It's not just buying a new box, but how hard it it going to be to stuff it into the place where the old box was ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
mike,
1) It's hard to find something in the code allowing for something. Only the disallowing parts are in there. I don't know either way would be a violation and the person who recommended a subpanel has done it on installations and it has passed inspection.
2) It's stucco and there's room for either a sub or a larger panel.
3) Oh yeah, that's in 1)
Another thing that could possibly be done is replacing several of the existing breakers with piggyback breakers to make room. As far as code goes for this, I think I need to look more into the panel and make sure it's not being overfilled if that is done.
Anothing thing is, they want to add another circuit or maybe even 2 for an electric gate and some outdoor lights.
I know it really sounds like they need a new panel and that's probably the way it'll go, but their budget is pretty fixed and I'm almost sure they'll be installing the solar either way, so it's kind of like I'm paying for their panel upgrade.
Well, I don't want to do bad work, so unless someone tells me something like "piggybacking or a subpanel is obviously the way to go" I'll tell them they need the service upgrade. If I'm not willing to make less money, I'll have to make the bid for a couple less solar panels.
