My Mickey Mouse charging installation.....
Everlong
Solar Expert Posts: 36 ✭✭
Please post what you see wrong with the picture, looking for advice. Thanks!
and yes, these are *marine* batteries, that i know;)
also disregard the anl fuse on one string.
waiting for blue sea terminal fuses.
Re: My Mickey Mouse charging installation.....
Um, it's out of focus?
You've mounted a whole mess of electrical stuff on a chunk of diamond plate.
The battery wiring looks pretty convoluted and appears to be 'laddered'. -
I believe that to meet code the batteries must be in a box, the cables must be in conduit. Also, the batteries cannot be under the equipment. --vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
Not sure code is an issue here, but am sure that the metal cases of the equipment is most likely grounded to (-) and then there's all those positive wires strung across that conductive metal plate. That's short-circuit city waiting to happen.
