Inverters with outlets converted to HARDWIRE option..
ywhic
Solar Expert Posts: 621 ✭✭
I know a few companies (Samlex) offer the terminal strips to hardwire there inverters to 110-120 AC panels and outlets.. does anyone know where to get them direct?? Samlex says you must special order from your local dealer when ordering the inverter (AKA.. not sold separately)??
Apparantly they fit in a standard outlet sized 'hole'... and just wire right in..
Anyone have a lead or an idea on how to simulate that?? I had found some 'barrier terminal strips' but someone must make the regular outlet thing like above..
Its for a cabin so I could just wire a 10/3 plug and then run that to my 'load center' that feeds the cabin, but I prefer something proper.. ideas accepted (with sample pics) on how to do this as I am sure I am not the only person to have EVER done this..
Re: Inverters with outlets converted to HARDWIRE option..I know a few companies (Samlex) offer the terminal strips to hardwire there inverters to 110-120 AC panels and outlets.. does anyone know where to get them direct?? Samlex says you must special order from your local dealer when ordering the inverter (AKA.. not sold separately)??
Since you are not in a grid-tie or even backup power situation, the power from your inverter should be similar to power from a generator. Attaching a socket (not a plug!) to your inverter would then allow you to run a suitable fixed or portable cord with a plug on the end to your load center.
Whatever option you choose, the output of the inverter must go directly to its own breaker in the load center (in this case it could be the main breaker) without any direct connection to any loads. (That is, if you use the terminal strip in an outlet box method, there should not be any other outlets on that circuit.)SMA SB 3000, old BP panels. -
Al, get creative!
Take the outlet out and see about adapting a standard junction box in its place. Bring your AC feed lines in through a knock-out (with restrainer) and wire nut them to the inverter wires like you would any junction.
The Samlex has its output circuit protection built-in (in order for the outlet to be safe) does it not? No need to buy their specially-adapted duplex replacement terminal strip just to make a safe, secure wiring connection.
I had (still have somewhere) an inverter with outlet on it that also had a standard wiring knock-out which allowed access to the connections for hard-wiring. -
Re: Inverters with outlets converted to HARDWIRE option..Since you are not in a grid-tie or even backup power situation, the power from your inverter should be similar to power from a generator. Attaching a socket (not a plug!) to your inverter would then allow you to run a suitable fixed or portable cord with a plug on the end to your load center.
The inverter I may get has GFCI outlets.. I was hoping to locate the DROP-IN like the one in the picture that fits the hole (and get rid of the possible GFCI issue before it starts).. another forum said I can't technically use an inverter for a cabin that has plugs and must go with a hard-wire 'TYPE' inverter..
That was my thought, just a wire with plug from the LOAD CENTER that simply plugs into the outlet on the inverter..
Could I bring it into the LOAD CENTER like a mains wire from the top and just feed the HOT backbone (and neutral & ground busbars), or do I have to run it into say a 30 amp breaker on actual the LOAD CENTER strip next to the OUTBOUND breakers?? -
Re: Inverters with outlets converted to HARDWIRE option..The inverter I may get has GFCI outlets.. I was hoping to locate the DROP-IN like the one in the picture that fits the hole (and get rid of the possible GFCI issue before it starts).. another forum said I can't technically use an inverter for a cabin that has plugs and must go with a hard-wire 'TYPE' inverter..
Load of dingo's kidneys. I have the only hard-wired system in any cabin on this lake, and my gen input is a plug.That was my thought, just a wire with plug from the LOAD CENTER that simply plugs into the outlet on the inverter..
External breakers on inverters in this sort of application are largely useless. My 3.5kW Outback will fault before any of the 15 Amp breakers trip.
The built-in GFI outlet on an inverter can be replaced with a non-GFI type. The outlet can then plug in to a load center or indeed feed household wiring (with or without additional fuses/breakers) so long as the inverter's output has proper circuit protection and the wiring is not undersized. We are not talking about a massive 48kW electric service here, but rather one that's the equivalent of a single 15 Amp outlet. -
Re: Inverters with outlets converted to HARDWIRE option..Cariboocoot wrote: »The built-in GFI outlet on an inverter can be replaced with a non-GFI type. The outlet can then plug in to a load center or indeed feed household wiring (with or without additional fuses/breakers) so long as the inverter's output has proper circuit protection and the wiring is not undersized. We are not talking about a massive 48kW electric service here, but rather one that's the equivalent of a single 15 Amp outlet.
Correct.. single 2000 watt inverter with GFCI, which I will probably replace with non-GFCI and then do the wire drop plan..
I may try to mock-up a hardwire panel (like I see on on some inverters) using a terminal barrier strip with cover.. or do like you said and try a patch panel with knock-outs and hardwaire..
I will put breakers in the load center for the outlets and such.. in case I do end up running a 'genny' (if the batteries or low or I need more JUICE to the circuits) I will have some breaker protection as well.
I was just hoping someone would know someone in the electrical 'business' and maybe point to a MFG for the drop-in..
I like the fact the drop-in fits right in the standard size hosuing and the screws seem to be in the right place also.. -
Hi, did you find a solution? I'm trying to do the same, connect a modified sine wave inveter to a 20A breaker box. Any suggestions? can ne1 provide me with a diagram? I have this box
http://goo.gl/4UnxaZ
Thanks... -
Not sure what your asking, but I haven't seen a post from Al in 18 months or so...
Likely best to start your own thread...
With a modified sine wave inverter you likely need to worry about a bonded neutral and ground.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
So if your unverter has plug outlets on it you can do. a couple of things the first is to crack open the inverter (warranty be darned) and connect your standard code compliant electrical cable with a neutral, hot, and ground connection being connected to their respective wires using code compliant connection methods. The second option is to get single male/female extension cord one for each outlet and cut the femal end off, plug in the nake end to the inverter and wire the other end into the plug outlet. each outlet will require two extenson cords and on the outlet side you need to remove the connection tab on each side of the outlet to spearate the metal plate that the screws that hold the wires on the side of the outlet screw into. This will separate the upper plug outlet from the bottom one so as not to overload the circuit and continuosly trip the breaker or worse cause a fire. the final option is to run wires from the inverter running all of the wires that would have gone to the inverters plug outlets and combine them and run them in parallel into a breakout box connecting them to the bus bars so you can then connect breakers in there and run your outlets off of there. That is probably the safest method if you are using an inverter in a structure. just be sure not to exceed the amperage of the inverter in total of all breakers. for example 1500watts = 15 Amps. running more than 15 amps will result in the breakers tripping and prolonged use or forcing the breaker not to trip like is done with well and septic pumps. Anyway there is a ton of information on the 8th wonder of the world of which you are on now that explain the how to's of the setups and when in doubt consult an electrician. even if they refuse to do it for liability reasons they can at least direct you with a method that wont result in a fire or electrocution. Do not do as others in this thread have suggested "play around". to rip of RAID Electricity kills people dead.
- 231 Forum & Website
