How does this sound for Magnum inverter + accessories
We're trying to complete our system and will be going with:
MS4448PAE Pure Sine Wave Inverter/Charger: http://www.solar-electric.com/maenms4444wa.html
White Steel With 250a/125 VDC Inverter Breaker: http://www.solar-electric.com/mne250stm-l-240.html
Magnum ME-ARC50 Advanced Remote Control for Magnum Inverters : http://www.solar-electric.com/mameadrecofo.html
The local company has quoted us the following:
Inverter: $1800.00
Display: $190.00
E-Panel: $620.00
Surge Arrestors: $180.00 ($90 x 2=$180.00)(You need three - but you already have one that we can use)
Breakers: $48.00
Shipping: $50.00 From the distributor to Arizona.
Approximate Total: $2,888.00
I understand I can save on individual parts online, but as a package, this is the best deal we've found.
We're right here in AZ and looking to buy local but NAWS is higher than the local guy or we would consider them.
Thoughts?
    BB. Super Moderators, Administrators Posts: 33,742 admin
    Re: How does this sound for Magnum inverter + accessories
    My only question--I believe there are two different remote meters:
    Magnum ME-RC50 Remote Control
    Make sure you get the one your need.
  • Chris Miller
    Chris Miller Solar Expert Posts: 49
    BB. wrote: »
    This is based on the ARC50... I was told it was the latest generation, and the one I would need?
    I don't know--I am not in the solar biz and mine is a Grid Tied system.
    As I understand, the "Advanced" meter allows you to access more programing registers/options in the inverters/devices... (from that I have read).
  • KeithWHare
    KeithWHare Solar Expert Posts: 140 ✭✭✭
    From reading the Magnum specifications, the ARC50 is what you want with the MS4448PAE.
    You may also find that a battery monitor kit (ME-BMK) would be useful. The Battery Monitor will provide info about amps going through the shunt and the battery state of charge on the ARC50 displays.
    Keith
  • Eric L
    Eric L Solar Expert Posts: 262 ✭✭
    Keith is right; I have all three (ARC-50, MS4448PAE, ME-BMK) and they make a nice package with good program-ability. To get the BMK to give accurate state of charge readings you have to spend some time adjusting the battery efficiency settings. But eventually it works pretty accurately (as I've confirmed by double-checking it with battery specific gravity readings).
    One little cool thing if you get the BMK+ ARC-50; you can use it to infer the amount of power coming from the panels/charge controller(s) if you're using the ARC at a remote location where you don't have a charge controller readout. You basically look at the DC amps going in or out of the batteries, add the DC amps going to the inverter, and multiply that by the battery voltage (the ARC shows you all these things).
