No charge controller?
Volvo Farmer
Solar Expert Posts: 209 ✭✭✭✭✭
Just wondering what you folks thought of this... I recently got a used golf cart with six T105 type batteries in it wired for 36V. I scrounged up what I believe to be three 50W solar panels that will fit on the roof. I think I'm going to get somewhere between 2.5 and 3 amps out of these panels. So I'll be charging at something lower than c/30. Do I even need a charge controller? I might use a little water, but is there any way I'm going to hurt full batteries charging at this rate for 5-6 hours/day?
I suppose if I actually run the batteries down 50%, there's no way they are going to get fully charged, even if I let them charge for two weeks between uses. Anyone have an opinion on that? Golf cart charger is a major load on my off grid system!
Re: No charge controller?
With such a small charge current, you probably don't need a controller. On the other hand, if you actually use the batteries to power anything, they're not going to get recharged, and that will kill them. -
There are some other threads on the forum regarding charging 36 Volt golf carts from solar panels. Most of them were dealing with larger panels, but the basic inequity still remains: a lot of battery with a little panel.
Let's see what we can find:
http://forum.solar-electric.com/showthread.php?9193-36-volts
http://forum.solar-electric.com/showthread.php?9680-Charging-36V-golf-Cart-battery-bank-with-3-12V-panels
http://forum.solar-electric.com/showthread.php?10309-Solar-Power-for-EZ-GO-Golf-cart -
Generally, raw panels do not have anti-backfeed diodes in them, they rely on the charge controller to do that. So with 5 sun hours, and 12 night hours, you may DISCHARGE the batteries, unless you put a diode in, or disconnect at night.
Look for about a 10 A Schottky diode to do the job http://www.solar-electric.com/blocdiod8amp.htmlPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
