Blue Sky - SB50DL
stooper2
Solar Expert Posts: 41 ✭✭
Hello Everyone.
Just a quick question about this controller.
When using the automatic equalization feature, the LED will flash rapidly. How do I know when the batteries have been equalized?
Thanks for everyones input and have a great weekend.
Re: Blue Sky - SB50DL
The [magic 8 ball] owners manual should explain thatPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Stooper,
As best I can tell, the SB50's EQ function is entirely manual. You release the EQ button to start the process, and you push the button in to stop it.
HTH,
Jim / crewzer -
crewzer is 100% right and be sure you never put stuff on top of the controller, even temporarilly, as it could activate the eq function. that is one complaint i do have on the sb50 as that was poorly thought out in placing that switch there. -
Thanks for the reply guys. I looked at the manual. maybe I read it a lttle too quick.
Again, thanks very much for your help.
Rick
