Any need?
97TJ
97TJ Solar Expert Posts: 68 ✭✭
I plan on wiring my 45 amp charge controller and a power max 35 amp charger to a buss bar before going to my battery bank. My question is, do I need any fuse or breaker in between the buss bar and the battery bank? I plan on a disconnect between the solar panels and the charge controller and the power max charger will run directly off a inverter generator.
  • Photowhit
    Re: Any need?
    Always nice to have a fuse at the battery, any mistake and while wiring and you could arc the capacity of your battery across what ever shorts across the wiring, think heating filliment.
    To be honest, I don't but I have a breaker about 4 feet away, still gives potential for problem in my 'power center, where I have 2 ends of 0000 cable coming in, so I've decided when I move the battery I'll add a fuse at the battery terminal.
