Open source monitor for Morningstar
jepefe
Registered Users Posts: 3
Do not know if is the correct forum but I would like to introduce the solar production monitor that I have developed.
For now only works for Morningstar MPPT.
It is open source software and you can see it in action here:
http://www.jeperez.com/monitor-solar/
Source code and installation instructions:
http://www.jeperez.com/monitor-solar-instalacion-codigo-fuente/
Sorry, the website is in Spanish.
Re: Open source monitor for Morningstar
Welcome to the forum.
I'm going to try this out in Solar Product Review & Opinions because it looks like you're asking for input, which is a good thing.
There's at least a couple of forum members who live in Spain who may be able to read the web site in its native language.
Best of luck for your product!
I stickied this post for now to get more feedback on it
-- Windsun -
Hi Jepefe, and welcome to the forum. As you already know, I think your software looks great, now I just need to find a router and the time to install it
On the other forum you mentioned that you've added the ability to control wireless relays based on the values from the morningstar, could you tell us a bit more about that? Can everything be controlled from a single openwrt router without the need to use any additional servers/devices ? -
I belive Solar Guppy has some MS monitor sw on his site too - http://www.solarguppy.comPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Open source monitor for MorningstarI believe Solar Guppy has some MS monitor sw on his site too - http://www.solarguppy.com
Looks like his web site is for sale. Too bad
"solarguppy.com is For Sale for $499!" -
Re: Open source monitor for Morningstarwaynefromnscanada wrote: »Looks like his web site is for sale. Too bad
FRaQing Squatters !!!! -
His site is: http://www.solar-guppy.com/ and the software requires a full blown windows computer. -
Hi!
I know there are other monitors but I wanted to present the software I developed as I understand it might be interesting for some people.
One advantage is that it is open source and you can modify to suit your needs.
Stephen,
do you know you can use the monitor connecting the TriStar directly to the Internet without OpenWRT router? Although I prefer to use the router to isolate the regulator d
About what I said in another forum about the relays, is still under development. Tests have worked well but I'm redesigning to make it cheaper, I estimate it will cost to make 13 € for each slave and 10 € for the only master that must be connected to the router, now also has the advantage that the communication is bidirectional and can know the true state "wireless relay." It remains to be developed but the idea is you can check the weather forecast and act activating or deactivating consumption.
It will be open hardware and open source. -
Re: Open source monitor for MorningstarCariboocoot wrote: »Welcome to the forum.
-- Windsun
Hi Cariboocoot
I had not read, thanks for stick the post! -
Hello,
The biggest problem for me, is that I only have Apple computers.
I have two TS-60 Mppt's that have a 1,200w 24v array to each MPPT. Two 600w 3-phase wind turbines rectified to 24v DC connected directly to the main battery bus bar to assure the turbines are always under load, and three TS-60 PWM's in diversion mode to assure my bank never over-charges in my single system. I am using the MeterBus hub's for the remote monitor, as well as four RSC-1 so I can connect all controllers from RS-232 to EIA-485 into one TS-60 MPPT to use the Ethernet.
I simply want to see the battery bank SOC. All the solar charging amps coming in, and what is being diverted. In real time, and over time.
It is so frustrating that I have all this kit, and I can only use a Microsoft Windows computer with MSview to see only one controller at a time, download files into a spreadsheet, and then see what happened... There has to be some easier and convenient way to monitor a system with more then one Morningstar controller. I am a DIY person (limited computer language knowledge), and can't see paying some company to remote monitor my system to get the accumulated data this is inside the hardware I already own !!
Alan -
Do you know the -60 MPPT's have a web server inside each ? hook them to a wireless router, and you can use any browser to monitor their activity.
If you're a DIY person, there are a number of ways you can monitor multiple Morningstar Tristar TS-MPPT-60 units. You can, as mentioned above, connect them to Ethernet, but you'll still have to log into two separate controllers. However, if you have experience with Arduino/Basic Stamp/Microchip PIC/Parallax Propeller or any other related microprocessor platform, it's relatively trivial to wire up several RS-232 cables from the MPPT units to the microprocessor, have it read the MPPTs, and do pretty much anything you want with the resulting data. It could send the data to your Mac via serial-to-USB converter, log it for storage, display it on a cheap LCD screen, etc.hkalan said:Hello,
Alan
Me personally, instead of buying a $100 Morningstar Tristar meter to see what was going on, I just made my own with a Parallax Propeller and VGA touchscreen...easy does it for about $30! I am more than willing to share the "Spin" source code for the Propeller if anyone's interested in making their own display unit. The TS-MPPT-60 uses the MODBUS communication protocol over RS-232 @ 9600bps (8 bits, 1 stop bit), which is standard, and a piece of cake for most microcontrollers to handle. (Code in this screenshot not quite finished: solar temperature/percentage are placeholders. Note that the MPPT does not update the "max power point sweep" registers if it's not in Bulk mode. I still haven't figured out how output wattage can be higher than input wattage, though!)
You can use the web server in each MPPT-60, to monitor via a browser, on a computer. You will need MS View for firmware updates. But you can use MS view over the web interface to download the log files. I have mine hooked into a wireless router, and from my office, I can monitor the battery state.
