more questions
Thomas
Thomas Solar Expert Posts: 291
would there be a conflick with a mppt charger and a mppt grid tie inverter? prob. been asked before, boring:blush:
Always troubleshoot with adequate sunlight.  Hi Ho Hi Ho
2.3kW [10] Enecsys SMI-240-60 micro inverters
    Re: more questions
    Yes, you cannot share the same array with two or more MPPT charge controllers. They will confuse each other. As one MPPT controller starts to draw more current, the other controller will think that the voltage is sagging and reduce its current draw.
  • Thomas
    Re: more questions
    Any reason why the inverter stoppedfunctioning at small amp levels and now only seems to be working at 14A only??
    I think my batteries noticed this too! Is is somthing in the grid?
    Re: more questions
    an mppt controller is used in battery based systems and the mppt inverter would be a grid tied inverter and are usually batteryless so no need for a mppt controller.
  • Thomas
    Re: more questions
    Mine indicates it can be used with batteries and treats the batteries after dark the same way it treats the panels during the day, mppt for 14a.
