114% quantum efficient solar cell - in the lab
techntrek
Solar Expert Posts: 1,372 ✭✭✭
NREL has tested a solar cell in the lab which outputs more electrons than photons going in. The additional output is captured from high-energy photons creating more than one electron-hole in some cases. Took over 10 years to go from theory to a working model in the lab, so don't expect this on your roof any time soon.
http://www.physorg.com/news/2011-12-scientists-solar-cell-electrons-photocurrent.html
Re: 114% quantum efficient solar cell - in the lab
unless i'm misreading this, you can't get more out than what is put in. there is only a certain amount of solar energy that hits the earth and you won't be able to get all of that energy let alone more. -
From the article:
Quantum dots, by confining charge carriers within their tiny volumes, can harvest excess energy that otherwise would be lost as heat – and therefore greatly increase the efficiency of converting photons into usable free energy.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: 114% quantum efficient solar cell - in the labFrom the article:
that's wonderful, but there is still only 1000w/m^2 on average of solar energy that hits the earth in all forms and you can't get 114% of 1000w/m^2. now maybe they are getting 114% over some of the present solar cells which is more within the realm of possibility, but i'd still be skeptical. -
What they are getting is 114% of a single photon -> electron energy transfer. The process produces a photon -> two electrons with each ~1/2 the power transfer from the photon. A single electron can only receive so much power (less than 50% , close to 40%) so in theory two at half power could transfer 80% of the total power from the photon. I'm skeptical it will ever be cost effective. -
I'm always concerned when someone uses numbers over 100%. "101%" is just 4 randon digits, AFIC.
It would earn you an F in a math class. I know. I remember.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
this one is far more realistic vis a vis making it to the market
http://forum.solar-electric.com/showthread.php?14072-Chemistry-Professor-Sheds-New-Light-on-Solar-Efficiency
Re: 114% quantum efficient solar cell - in the labwestbranch wrote: »this one is far more realistic vis a vis making it to the market
The other way is direct conversion of photon energy by tiny light-wave antenna/rectifiers on a chip.
http://www.coolcadelectronics.com/DARPA_Energy_Harvesting.html
A real device, like with most of these things is a long way off.
http://en.wikipedia.org/wiki/Nantenna -
what you guys may be missing here is that an antenna is a narrow band device, aka resonant. when it becomes a working development it may only work well in a narrow part of the spectrum. many see this type of curve already on pvs where it rises toward the smallest wavelength of infrared spectrum where it just about enters into visible light and then may start back down again in its response from there. what this may do is just allow a pv to be made for the lower and mid infrared ranges that will not respond as well to visible light. in essence, it's a trade off on wavelength and will not necessarily collect any more power than present technology. -
Re: 114% quantum efficient solar cell - in the labI'm always concerned when someone uses numbers over 100%. "101%" is just 4 randon digits, AFIC.
Mike if you lent out money at 10% per month what is the per annum rate?? -
Re: 114% quantum efficient solar cell - in the labMike if you lent out money at 10% per month what is the per annum rate??
Simple or compound?
Its not relevant to the question. .As there is no amount of money given .therefor its only the percentage figure asked. -
Completely relevant, thus the difference between rate and effective annual percentage rate on loan documents.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: 114% quantum efficient solar cell - in the labwhat this may do is just allow a pv to be made for the lower and mid infrared ranges that will not respond as well to visible light. in essence, it's a trade off on wavelength and will not necessarily collect any more power than present technology.
And what happens to the glare study? Would these panels reflect low and mid infrared waves to a degree that they would confuse insects who see in these ranges? Is reflected infrared going to cause sunburn, interfere with security cameras, assist night-vision glasses, or screw with remote controllers in it's footprint? There are so many infrared devices in the general public, that panels may inadvertently cause electronic dead spots instead of warped vinyl siding. -
Do they get colder when the sun shines on them? -
nobody said the panels would reflect the infrared and they do that now anyway to one degree or another like most things that are shiny or reflective. it's irrelevant.
as to insects, well i just haven't asked any of them lately if they are getting confused. have you asked them and if so please tell us what they said?:roll::p
it is true that reflected infrared can warm you up, but the tans are from the other side of the light spectrum called uv.
all of the items you list take advantage of ir at night and wouldn't affect them detrimentally regardless. -
Re: 114% quantum efficient solar cell - in the labwhat you guys may be missing here is that an antenna is a narrow band device, aka resonant. when it becomes a working development it may only work well in a narrow part of the spectrum. many see this type of curve already on pvs where it rises toward the smallest wavelength of infrared spectrum where it just about enters into visible light and then may start back down again in its response from there. what this may do is just allow a pv to be made for the lower and mid infrared ranges that will not respond as well to visible light. in essence, it's a trade off on wavelength and will not necessarily collect any more power than present technology.
It's pretty easy to make wide-band (~10:1) unity gain antennas with at normal RF frequencies. The same principle can be used with light with shaped feed elements.
http://en.wikipedia.org/wiki/Discone_antenna
http://classes.yale.edu/fractals/panorama/ManuFractals/FractalAntennas/FractalAntennas.html -
yes, i'll agree that some antenna designs may work well enough to overcome the narrowbandedness to some degree, but it will still be a resonant type thing. remember the multi-layered pvs that responded to various wavelengths? that was a similar idea. -
Yes, Tandem PV junction cells are one way to bypass the http://en.wikipedia.org/wiki/Shockley–Queisser_limit
The problem with direct photon conversion is not really the antenna system, it's the (quantum
mechanical tunneling) diode needing to work at 150Thz with high efficiency that's the tough nut to crack.
