insolation and short circuit current equation
zubair
Registered Users Posts: 8 ✭
how the insolation is related to short circuit current. How this fomula was made "G = Isc / 1000". where G = solar insolation in watt/m^2 and Isc = panel short circuit current.
Re: insolation and short circuit current equation
More or less... Say you have a panel with Isc=2.5 amp at 1,000 W/m^2.
Then the true W/m^2 would be:- W/m^2 = Isc (measured) / Isc@1,000 W/m^2
- W/m^2 = 0.5 amps measured / 2.5 amp Isc per 1,000 W/m^2 = 200 W/m^2
Isc is directly proportional to insolation but not a direct equal equation without a few more factors.
The size of cell and efficiency effects the result. Temperature effects to a slight degree with more current produced when cell is hot at a 0.03% to 0.05% increase per deg C. It is the size of one primary cell, not how many are connected in series within a panel.
Assuming a good quality mono or poly silicon cell, the current produced for the area of a cell is 32 mA to 35 mA per square centimeter at full sun of 1000 w/m^2.
