panel parallel and series wiring help
larrybc1
Solar Expert Posts: 44 ✭
I have 16 evergreen 210 watt panels and plan to wire them as follows:
4 in parallell and series of 4..the specs per panel are: VOC 23.1..VMP 18.3..IMP 11.48 amps..will feed into a MNP-6 combiner box and then either a classic 150 or Outback FM80 (havent decided yet) controller..does this wiring setup sound ok?
thks larry
thks larry
Re: panel parallel and series wiring help
Your batteries will be set up for 48 volts right? -
Re: panel parallel and series wiring helpwaynefromnscanada wrote: »Your batteries will be set up for 48 volts right?
Is the reason for that question due to his system producing 89a for a 24v system and 43a for a 48v? 89a would exceed the Outbacks ability, correct? -
Yes 48 volts battery bank..
