Integration of Panels into Tiled Roof
HI Forum
Back again, had to get married and was rather busy :).
Anyway we've got our first installation as a new small company here in southern Spain.
We are trying to improve a poorly designed and installed installation. We will be adding 6 kyocera 120W panels to the array with an additional 60A regulator.
My question is what are the best methods for integrating solar panels in a tiled roof?
As you can see from the picture, the previous installation is done in a pretty ugly fashion, and we intend to integrate the new ones more aesthetically into the roof.
Any guidance much appreciated
Larry
  • ggunn
    Re: Integration of Panels into Tiled Roof
    lazza wrote: »
    HI Forum
    Larry
    I take it that there is never any wind at the site of that installation. Wait, isn't that a little wind turbine in the background? ;^)
    There are companies that produce racking mounts for tile roofs, but it's not cheaply or easily done. I googled "PV racking tile roof" and came up with several hits, but I have no firsthand experience with any of them.
    Good luck.
    Buy spare tiles before starting ! And if the underlayment (tar paper) is +20 years old, maybe it's worth doing that replacement before you put panels on . Tile is just not very easy.
  • newenergy
    newenergy Solar Expert Posts: 291 ✭✭✭✭✭✭
    I'm know there are some European companies that make tile mounts. I use QuickmountPV or Prosolar, but they may not be available.
    From the looks of it those are pretty fragile clay tiles and yeah buy extra, but we will also commonly remove the tile in the section under the array, install comp shingle and the put tiles back around the array. But, that doesn't seem worth it for such a small array.
  • SessionMan
    SessionMan Registered Users Posts: 8 ✭✭
    With tile roofs like that you definitely need to pay special attention to the flashing. Using either Creotecc tile hooks or quickmount curved tile flashing would be the best bet.
    Here is a good video of an installation for a slightly different style of tile.
    http://www.sessionsolar.com/videos/creomount-animated-install.html
    SessionMan,
    That was a very nice video on tile roof installations.
    Thank you,
  • SessionMan
    You are quite welcome, I actually work for the company who made the video, though I'm posting out of personal desire to see solar succeed. I do design support for large systems as well as designing our new line of product.
