Flexcharge Night Watchman?
MichaelJ
Registered Users Posts: 23 ✭✭
Is anyone using this dusk to dawn 12v dc photocell for night lighting. Rated at 10a incandescent and flourescent lighting. The standby is 0.15ma.
I searched the NAWS site, but found only the digital timer.
One 11w flourescent bulb is the load, and the cost is a factor, $30 for the photocell.
Appreciate any info or feedback on the product.
Mike
Mike
Re: Flexcharge Night Watchman?
I use a salvaged photo-transistor to trigger a 555 chip, which then powers a 12 VDC relay. Been working perfectly for probably 20 years now. -
would you mind sharing the circuit with others?
sounds like a great item. i've been looking for a simple circuit to operate some led lighting. -
NAWS does sell a DC motion detector:
Infrared Motion Sensor - 12 volt 10 amp (not cheap)
I like those over dusk to dawn setups for security lights.
If you are into kits--here are a couple (these are complete modules, not kits themselves) you can connect up with a STAMP micro controller:
X Band Radar motion detector ($30)
PIR Sensor 3-Pin ($10)
The two above use ~5VDC and ~8-23 mA to operate with a maximum of 30 foot range.
I have not used these devices, but have purchased stuff from Jameco before without problems over the years (they are only a few miles from my home).
Thanks for the replies. The application is not for security, just to provide light from dusk to dawn. A timer would be overkill. The photocell will do the job.
I will be ordering the Night Watchman, and see how it goes.
It was developed for use on boats, something about a required light on the mast at night. But it's the best fit for my need.
Mike
- 234 Forum & Website
