Eva encapsulation
edanthony
Registered Users Posts: 7 ✭
Hi folks,
When sealing solar panel with eva encapsulation using a heat gun, I wonder if the cell wont get brittle and will break if subjected to intense heat? What is the ideal temp?
Thank you, I appreciate your comment on this.
Re: Eva encapsulation
Here is a pretty good series of posts of how to build your own solar panels:
http://fieldlines.com/board/index.ph...,144982.0.html
http://fieldlines.com/board/index.ph...,144995.0.html
http://fieldlines.com/board/index.ph...,145004.0.html
you can buy panels for less than 75cents a watt, only issue is you have to buy over a $1100 at once and with freight you are looking at $1300 minimum purchase.
So unless you are making one or two small panels less than 100 watts it is not worth it to make your own.
