Monitor Windseeker output
denlow
Registered Users Posts: 8 ✭
I am brand new to off grid systems and we have recently purchased our retirement home. There is a old windseeker mated to a PV system and propane generator. There are sixteen 70 watt BP panels, 20 Trojan 105s (24 volt configuration), Outback controller and Trace inverter. My question is how can I best monitor / check the output of the Windseeker? Is there a specific meter I could install that would show what output I am getting from the wind generator?
Re: Monitor Windseeker output
With both wind and solar, you should have 2 controllers also. Maybe the windseeker has one internally.
You can go as simple as an amp meter for a car, or a digital recording meter that will tell you what time of day, it produced how much. Some charge controllers log the data, and a PC can download it.
But unless the wind is strong enough to blow your hat off every time you step outside, I would not count on much power from it.
MikePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Monitor Windseeker outputI am brand new to off grid systems and we have recently purchased our retirement home. There is a old windseeker mated to a PV system and propane generator. There are sixteen 70 watt BP panels, 20 Trojan 105s (24 volt configuration), Outback controller and Trace inverter. My question is how can I best monitor / check the output of the Windseeker? Is there a specific meter I could install that would show what output I am getting from the wind generator?
One of these may possibly do what you want. http://www.tlgwindpower.com/ccontrollers.htm
- 621 Discussion Forums/Café
