Morningstar MPPT Presets
Wanderman
Wanderman Solar Expert Posts: 180 ✭✭✭
Anyone know why the #6 preset for the Morningstar MPPT controllers sets the voltage at 14.7? Is there a battery out there (Lead Acid) that wants this as a charge voltage?
I ask, because Trojan is looking fro 14.8V and to get that I will have to program custom set points. Not that 14.7 WON't work.....
Just curious.
Rick
  • waynefromnscanada
    Re: Morningstar MPPT Presets
    If I remember right, it's a setting Morningstar came up with, specifically for L-16's.
  • Wanderman
    OK... I wonder if it's worth setting up a custom 14.8v preset for Trojans?
    Also, why don;t the have a "prettier" interface for their monitoring software...you'd think people would like to have a flatscreen on the wall with all the data at their fingertips.
    Rick
    Probably not... Do you have a Remote Battery Temperature Sensor setup?
    That can be worth the money with faster/better battery charging and helping to reduce the chance of thermal run-a-way (charging battery, battery gets hot, charging voltage drops, charger thinks more charging current/time needed to charge battery, battery gets hotter and eventually fails/melts down).
    Probably not going to have a meltdown with 10% rate of charge from solar panels--But you should get much better charging.
  • Wanderman
    BB,
    The remote Temp sensor was installed from the beginning, along with remote battery voltage sense. More efficient that way.
    I have been seeing 14.7V charges regularly....not sure if the extra .1V is worth too much Amp/Hr or battery longevity wise.
    What do you think?
    Rick
