Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Underground Windmill
  1. #1
    Default Underground Windmill
    Just when I thought we had heard it all. This underground windmill is 280% more efficient than current models. They state that birds and bats have nothing to fear from this new technology.
    www.sheerwinds.com
  2. #2
    Join Date
    Oct 2010
    Location
    Nova Scotia canada
    Posts
    2,837
    Default Re: Underground Windmill
    But what about the poor earth worms? What about ground living creatures like moles and such? What are these people thinking?
    Not Under My Back Yard!
    Pour on the coal and oil, I want electricity and I want it now!
    1900 watts PV, (1000 watts PV feeding MidNite Classic 150; 900 watts PV + 160 watts micro hydro both feeding into a single shared Morningstar TS-MPPT-60) ; Xantrex Pure Sine 1800/12 for heavy loads; Xantrex Pure Sine 1000/12 on 24/7 for everything else; six Rolls Surrette 2 volt L16 @ 12 volts.
    Domestic hot water totally provided by the sun 8 months out of every year via thermal panel.
  3. #3
    Join Date
    Jun 2007
    Location
    Williams Lake, BC
    Posts
    3,384
    took a bit of 'follow the links ' (not much on their website) but got a good description out of these 2 articles
    http://www.mn2020hindsight.org/view/...nes-you-betcha
    http://www.earthtechling.com/2011/12...er-on-horizon/
    very interesting but to me it appears to be large scale for a long time...
    100% Off Grid @ 51* 46' N lat 124* 44' W long
    New House system: coming - 2 arrays @ 2240W
    CL150&Epanel 2 @140 W 12v PVs , 24V C&D AT-15P AGM @ 950Ah
    + CL150 2@120W 12 V panels, 24V C&D AT-15P AGM @ 950Ah
    Cotek ST1500W inverter, TBS 30a-24v Omni-charger, Honda Eu3000is,
    Guest cabin system: 3 - 70W panels to SB 2000e CC, with 2 - 100 ah 12v SAFT wet NiCd's , 600W TSW Inverter
  4. #4
    I would worry the intake horn could create a low frequency oscillation resulting in a very powerful "brown note".
    http://www.audiocheck.net/testtones_brownnote.php
  5. #5
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    i'll bet it scares away ground hogs too.
    if the first description i saw they used a cone faced into the wind it would force the wind to that point below and would exit on the ground. this one would need something to keep it facing the wind like a tail, but would work imo. to me the 2nd link as shown can't do any thing as there's nothing forcing the wind down into it as it would just bypass it and i see no exit that isn't being acted upon with the same equal force so the 2nd one is just an oversized inground ground hog chaser.
    NIEL
  6. #6
    This is a "WAG" but it looks like a horn tapered to the generator , on top of the main horn is another horn (open at the bottom) with a gap feeding into the first horn. In the gap between the two horns the wind would create a vortex that would create a pressure gradient from the top of the second horn and the feed throat of the main horn. This pressure gradient would start the movement of air into the feed tube to the generator.
  7. #7
    Join Date
    Jan 2011
    Location
    Baltimore, MD
    Posts
    157
    Quote Originally Posted by sawmill View Post
    www.sheerwinds.com
    Wouldn't the bats try to roost in the dark, cave-like tunnels, and then get sucked into the turbines and killed when the wind blows?
  8. #8
    Join Date
    Sep 2006
    Location
    Willits, CA
    Posts
    5,810
    Quote Originally Posted by jagec View Post
    That's how the bearings get greased.
  9. #9
    Quote Originally Posted by nsaspook View Post
    This is a great example of how a vortex can cause a pressure gradient:
    http://www.youtube.com/watch?v=zgFvy...eature=related
  10. #10
    I swear - I don't know how you guys keep coming up with this stuff...
    This can't be very efficient... Since air is like water and electricity - it takes the least resistive path...
    There is a really big difference in the mechanical force generated by 30-60 foot radius propeller blades and a 60 foot cone.
    Has anyone seen any working prototypes?
    I am leary of this - but trying to keep an open mind - ya never know, they may actually be able to pull that rabbit out of that little itty bitty hat..
    Dave
    Phoenix, AZ
Similar Threads
  1. NEC question - PV rated wire for underground conduit run??
    By JasonPAtkins in forum PV Installers Forum - NEC, Wiring, Installation
    Last Post: December 4th, 2013, 12:49 PST
  2. LPG for generator in semi-underground building
    By stephendv in forum Off Grid Solar & Battery Systems
    Last Post: November 10th, 2012, 0:31 PST
  3. Battery Bank underground in concrete structure, good idea?
    By logaholic in forum Off Grid Solar & Battery Systems
    Last Post: May 14th, 2012, 14:03 PDT
  4. How to wire from pole to underground box
    By gtxkid in forum Wind Power Generation
    Last Post: September 12th, 2010, 17:44 PDT
  5. Electroendosmosis Underground PV Circuits
    By tbro723 in forum PV Installers Forum - NEC, Wiring, Installation
    Last Post: March 21st, 2010, 14:43 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
