Evergreen Panel Question?
biznitch15
biznitch15 Registered Users Posts: 7
Novice and Dumb Question?
How Much can FOUR Evergreen 195W panels power up with an off grid sYstem (average) ?
(All i need is a Simplified Answer, I'm still a Beginner) I'll get into Specs Later, Thanks!
    Re: Evergreen Panel Question?
    You can harvest about 80% of your panel rating. (780W) x .8 = 625W
    You can store that all week and run a micorwave oven for an hour, or run a small light forever. It all depends on your load you want to power
  • System2
    System2 Posts: 6,290 admin
    Maybe 100 watts continuously if you had 1000 Amp-hours of battery, depending on... everything.
  • icarus
    Just for comparison, we have ~200 watts of panels, and we use ~ 36 amp/ hours a day (12vdc) or about 450 watt hours, or 7.5 hours with ONE 60 watt bulb! 3 days without sun and we have to run the generator to keep the batteries above 80% soc.
    Assuming near Oakland CA---195watt x 4 off grid system with fixed mounts, optimum siting, assuming inverter AC output... Use this link, and for derating use 0.52 to account for flooded cell battery inverter losses:
    1kW of panels (program does not go any smaller than 1kW):
    80-100kWhr per month (summer)
    50-60 kWhr per month (winter)
    Multiply the above by 4x195w/1,000w (your panel size) and by 1/30 for daily power:
    80-100=> 2-2.6 kWhr per day (summer)
    50-60=> 1.3-1.5 kWhr per day (winter)
    That is about $0.15 to $0.30 of electricity per day.
