Question about charging my battery bank using a second source
ghostofthenorth
Registered Users Posts: 13 ✭✭
Hi very helpful community. I've been reading on here for a couple of years, and just built my first system. Its working well so far, but I have a question about a backup charging source for my system.
I have installed 4 x 230W photowatt panels in 2 x 2 parallel-series connection to a Midnite Classic 150 CC, charging a 24V bank of 4 x CR430 batteries. My inverter is an ST-1000-124.
I followed as many recommendations as I could and so far everything is working very well. The setup is working in ~central (actual central, not what people call central) Ontario, Canada in an off-grid application. So far we typically take the batteries to ~95% charge after each night of use. I might have over spec'd the batteries a bit, though I want them to be able to handle low peak sun hour times of the year, such as Moose season and winter.
My question is the following: There are times that we will run a generator (for water pump and water heater), and I want to make use of the extra power to charge the batteries. Do I need to do anything to the CC when using the battery charger (powered by genset)? Does the Midnite Classic need to know in some way that the battery charger is charging?
I've tried searching the site for this, but haven't found anything specific to this question other than a very general "it should be ok". I'm curious for my specific CC (which so far I LOVE, thank you NAWS users) if there is any setting I should/need to set when using the external charger.
Thanks greatly in advance!!!!
GhostOfTheNorth
GhostOfTheNorth
No need to do anything special, just parallel the charging sources, the battery voltage will regulate both just use a quality charger particularly if using AGM, cheaper automotive ones can over voltage the bank if left unattended. It's also better to use one that can supply enough current to use the available energy, but not over tax the generator..
An example of the kind of charger which is well suited for such an application, there are other amperage version.
https://www.solar-electric.com/iota-engineering-dls-27-40.html
You may already be aware, but I'll throw one potential issue out there anyway.
Depending on charging voltages and whether you have a whiz-bang jr, the generator could end up supplying most of the charging current, and make the controller go prematurely into float. Using a WBjr to measure actual current to the bank (vs Classic output) avoids this. Setting the Classic to not use end-amps while generator charging would also avoid the issue.Off-grid.
You can probably find a cheap used 24v floor scrubbing machine charger and that should get you started.
You won't be able to use the inverter when it's equalizing.
I have one I bought from the scrap yard I was planning to use when I build a 24v system. Only makes 7 amps.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
Thanks for the quick feedback guys! I do have a Whizbang Jr in the set-up, monitoring the amps out of the batteries.
Glad I don't have to do anything too special, sounds like its a simple add.
Thanks Again!!
- 628 Discussion Forums/Café
