Lifepo4 replacement quandary
124»
    Bluesea has some latching relays upwards of 500 amps at 12 and 24 volts... May be expensive in the ~$250 USD range. These are designed to connect battery banks when charging--May need "hacking" for the disconnect function/control.
    https://www.bluesea.com/products/category/35/Automatic_Charging_Relays
    250 Amp latching solenoid:
    https://www.bluesea.com/products/9012/L_Solenoid_-_12_24V_DC_250A
    Dave Angelini Solar Expert Posts: 6,750 ✭✭✭✭✭✭
    Cool might help someone. For my money, this needs to all be done and tested by the people who build the battery.
  • Dave
    Dave Registered Users Posts: 59 ✭✭
    karrak said:
    Dave said:
    nevermind my last post, i was reading up and this PMC really doesn't do the same job as a BMS.
    I am puzzled, it looks like a BMS to me,does all the functions of a BMS
    • Monitors individual cell voltages and charging current
    • Will disconnect battery if cell voltages or charge/discharge current goes out of operational limits
    • Will keep the battery balanced.
    I think it will also output this information to a computer but am not sure about this. Am I missing something?
    Simon
    I called Electric Car Parts (ECP) today but unfortunately I had not seen this post so I didn't ask these questions. But, here's some explanation:
    The Protective Circuit Board management system (https://www.electriccarpartscompany.com/48V-512V-576V-Custom-Built-Lithium-LiFePO4-LFP-PCB-PCM) only had 70 mA available to balance so if there is much V discrepancy, it would take a very long time to correct. The battery balancer he recommended (https://www.electriccarpartscompany.com/3V-1S-Lithium-Lighted-Battery-Balancers) has 6 A to do the job.
    The setup he recommends is a battery balancer for each cell (16 for me) and then a battery manager (https://www.electriccarpartscompany.com/48V-100A-EV-BMS-Battery-Management-System) for the system. The BMS would provide the disconnects and do large scale balancing of the bank.
    Looking at ivor's earlier post it sounded like he was getting a battery bank for $2k (24V 400Ah as I recall) and that's a lot cheaper than it would cost thru ECP from what I could tell. That may apply to other components too. For some reason, I am nervous about ordering from Ali. For one thing, if there is a warranty issue, would you try to handle through them or the manufacturer? I suppose if you save enough on hte order, you could apply the savings to new components if that was easier than trying to get warranty coverage.
    12 * 300 W (10 fixed rooftop, 2 movable pole mount), Morningstar Tristar MPPT 60, Magnum 4448 PAE, 64 200Ah CALB in 4p16s arrangement with 16 LED Balancers and a Choice BMS300 (It is lousy and I don't recommend but it provides high and low voltage cutoff)
  • mcgivor
    The batteries arrived today, a week from order date, not bad.
     @Dave said. For some reason, I am nervous about ordering from Ali. For one thing, if there is a warranty issue, would you try to handle through them or the manufacturer? I suppose if you save enough on hte order, you could apply the savings to new components if that was easier than trying to get warranty coverage
    At first i was a little  apprehensive about Alibaba, perhaps the Ali Baba thieves association  :D , but in reality they act as a go between offering protection to the buyer by holding funds from the seller  until the transaction is complete and the customer is satisfied. When I imported cars from Japan to Canada I used a similar trade assurance company in Japan, as protection from shady operators. All my dealings  so far with Alibaba have been positive.
  • karrak
    karrak Solar Expert Posts: 326 ✭✭✭✭
    If the cells are all reasonably balanced to start with the high rate 6A balancers will be unnecessary. From the pictures the 48V-100A-EV-BMS-Battery-Management-System looks like it has a balancing function but the balance current would probably be around 70mA as well. Doesn't look like you can connect it to the outside world and it doesn't have a display.
    One function that a BMS should provide which is extremely useful is the SOC of the battery (battery fuel gauge).
    As for ordering from Ali I have ordered many different things from different suppliers and have never had any problems. I think Ali will help you if the goods don't arrive, are DOA or not as advertised but you are probably on your own if things go pear shaped a few months down the track. I always do an Internet search on the supplier and the product to see how much feedback there has been. For Lithium batteries and BMSes I suggest you have a look at the Endless Spheres Forum
    Simon
    Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
    32x90Ah Winston cells 2p16s (48V), MPP Solar PIP5048MS 5kW Inverter/80A MPPT controller/60A charger, 1900W of Solar Panels
    modified BMS based on TI bq769x0 cell monitors.
    Homemade overall system monitoring and power management  https://github.com/simat/BatteryMonitor
