How to charge batteries with two charge controllers using AC and solar?
Hi there,
I am very new to solar power but my boss has put me in place to design and set up solar power for our work to power . I am supposed to make a system that can charge the batteries from AC if the solar power is not producing energy. The only problem is I can only use the parts from an old system we inherited from a client. This system looks like it must have had two seperate systems connected with a generator at one point. There are two charge controllers an Outback flexmax 60 and a Solar boost 3024i. Is it possible to use bothe controllers to charge the batteries? one to charge with solar and the other to charge with utility when the solar is down?
thanks
  • PhotowhitPhotowhit Posts: 4,702Solar Expert ✭✭✭✭
    edited July 30 #2
    No, both the Flexmax 60 (FM60) and the Solar Boast3024i are NOT designed to charge from AC. You  would need a stand alone AC charger like those made by Iota.
    Solar boast manual;
    http://www.blueskyenergyinc.com/uploads/pdf/Manual_BSE_SB3024i.pdf
    Outback FM60 manual;
    https://ressupply.com/documents/outback/FM60_FM80_Manual.pdf
    Iota chargers;
    https://www.solar-electric.com/catalogsearch/result/?q=iota
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • EstragonEstragon Posts: 2,838Registered Users ✭✭✭✭✭
    I think @Photowhit meant both designed to charge from Dc (solar), not AC (grid).
    Thanks, I need a full time editor to watch my posts these days.
