Xantrex Vesta PDC (power dist center)
westbranchwestbranch Posts: 5,087Solar Expert ✭✭✭✭
I found one of these up for auction, unused, anyone know if the breakers etc are still avail?
manual states made in 2001.
thanks
Eric
  • JamesJames Posts: 246Solar Expert ✭✭
    Re: Xantrex Vesta PDC (power dist center)
    Hello,
    i have not been active at this forum for awhile.
    Are you looking for the breakers that go in the PDC or the Vesta Inverter system?
    If for the PDC, the distribution breakers are Square D QO type, available from home depot or other stores.
    The transfer breakers are square D QOU type. The 3-pole, 60 amp breaker may cost over $150.00 at electrical supply houses, I found mine on ebay for $20.00
    the 20 amp 2-pole should be about $10.00 on ebay.
    Email me for the seller link on ebay if you need the 60 amp breaker
    The relay boards may be hard to get from Xantrex
    good luck
  • boBboB Posts: 951Solar Expert ✭✭✭✭
    I have a couple of old Vesta prototypes in my basement that I use for parts shelves.
    boB :D
    (in San Diego today)
  • BaringsteveBaringsteve Posts: 1Registered Users
    boB, if you  are still out there, do you have a relay board for the PDC?
  • littleharbor2littleharbor2 Posts: 979Solar Expert ✭✭✭✭
    If not here you can find boB on the Midnite Solar Forum.
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
    I could also use a relay PCB with the relays intact, or even with out the relays if I could get the PCB.
