Whirlpool, 110V, 6.5 amp refridgerator
zilchllzilchll Posts: 2Registered Users
What would I need to run this fridge alone, no other items attached?
  • littleharbor2littleharbor2 Posts: 959Solar Expert ✭✭✭✭
    The numbers you provide are likely the peak numbers. 110 vac. x 6.5 amps = 715 watts. My 14 cu ft. fridge after monitoring with a kill a watt meter draws .75 amps while running. I never have tried to find the peak wattage being that our inverter is much larger than needed to kick start the fridge.
     Looks like a 1000 watt PSW inverter will handle the start up load.
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
  • mcgivormcgivor Posts: 1,894Solar Expert ✭✭✭✭
    edited April 27 #3
    Without any information on what is actually powering the refrigerator, be it an inverter powered  by a battery or whatever , it would be irreponsible to answer such an open ended question, without knowing the details, location ambient temperatures etcetra, these are factors which will determine sizing of array. . Only my opinion,  FWIW
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
  • BB.BB. Posts: 27,568Super Moderators admin
    For a standard, modern, energy star refrigerator, generally a 1.2 to 1.5 kWatt (1,200 to 1,500 Watt) AC inverter is recommended... It will generally also run a few lights, radio, cell phone charger, etc...
    What you do need is to measure the amount of energy per day (Watt*Hours) using a Kill-a-Watt or similar meter:
    https://www.solar-electric.com/kiacpomome.html
    Nominally, for an off grid energy efficient home, I would suggest around 3.3 kWH per day (3,300 Watt*Hour) system. If you really only want to run a refrigerator, lets assume that it draws around 548 kWH per year or (547kWH/365 days per year=) ~ 1.5 kWH per day. A full time off-grid "reliable" system may look like (loss of guesses here about your specifics). First sizing the battery bank:
    • 1,500 WH per day * 1/0.85 AC inverter eff * 1/24 volt battery bank * 2 days storage * 1/0.50 max battery discharge (for long life) = 294 AH @ 24 volt battery bank
    Say you start with 6 volt @ 200 AH "golf cart" flooded cell batteries. That would be 4x in series for (4x6volt=) 24 volts, and 2x strings in parallel for (2x 200 AH=) 400 AH.
    Note: A 400 AH @ 24 volt battery bank will support a suggested maximum ~2,000 Watt AC inverter and ~2,000 Watt solar array. Larger AC inverters typically waste power and will empty the battery bank very quickly if heavy loads are used.
    We suggest 5% to 13% rate of charge, with 5% good for weekend/emergency usage in sunny weather, to 10%+ for full time off grid:
    • 400 AH * 29.0 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 1,506 Watt array "nominal"
    Then there is sizing the array for your loads and amount of sun... Say you are near Tuscon with a fixed array:
    Tucson
    Measured in kWh/m2/day onto a solar panel set at a 58° angle from vertical:
    Jan Feb Mar Apr May Jun
    4.95
    5.63
    6.61
    7.07
    6.91
    6.56
    Jul Aug Sep Oct Nov Dec
    5.77
    5.66
    6.09
    5.84
    5.30
    4.76
    Based on hours of sun, seasons, and 1,500 WH per day, and a derating of 0.75 (you do not want to use 100% of your predicted power per day--Unless you have a backup AC genset for some days of less than clear weather):
    • 1,500 WH per day * 1/0.52 off grid system AC eff * 1/0.75 "no genset" fudge factor * 1/4.76 December average hours of sun = 808 Watt array minimum for "nominal" December usage
    So, somewhere between an 808 Watt and 1,506 Watt array would work. (solar panels are historically cheap, and battery prices are rising--Tending towards the 1,506 Watt array would be "very nice"--Especially if you do not want a genset).
    The above is a quick back of the envelope calculation for a "reliable" off grid system to run a standard Energy Star Refrigerator. Hot weather, using the ice maker, etc. can cause a fridge to use significantly more energy.
    You can, of course, go with a smaller system (like just one string of golf cart batteries and an ~808 Watt array)--But that does mean you will have to monitor the system more closely during hot or cloudy weather. Also note that I am using "accurate" numbers like "808" so you can follow me where the numbers come from... For solar power, +/- 10% (i.e., and array that is 800 Watts +/- 80 Watts in size) are pretty much "the same". Solar power numbers are "estimates"--Not etched in stone.
  • zilchllzilchll Posts: 2Registered Users
    Right now, the fridge is unplugged and not used. It is about 7 or 8 years old. I said it is 110 but I do not know the difference between 110, 115 or that stuff. It is a Whirlpool 10.7 cu. ft. When I looked it up online it said it was 6.5 amps. It is in a tight spot so the plate is hard to get to. We want to use solar to run it full time, if possible. I guess we need a panel and inverter, at least a 1000 watt?
    edited April 27 #6
    Do you currently have grid power and are attempting to power the refrigerator with solar in an attempt  to save on the costs versus  of running on grid, or are you in a location without grid and are in need of refrigeration? These are very important questions that need to be answered, because solar energy is not cheap, in fact it will cost way more than grid, anywhere any time, based on global grid energy prices.
  • 706jim706jim Posts: 205Solar Expert ✭✭✭
    I'm running a somewhat smaller fridge (rated 311Kwh/year) off the system listed in my signature. So far it seems to be working fine.
    Island cottage solar system with 1400 watts of panels, Trace DR1524 MSW inverter, Trace C40 PWM controller 8 Trojan L16's. My 25th year.
